Old 07-04-2014, 02:06 PM
leeklm's Avatar
leeklm leeklm is offline
Originally Posted by FrankieT/A View Post
The rear bushing in the tranny is the shaft support, so with no yoke you will have a lot of play. It must be checked with the yoke installed.
Correct. With the shaft installed, I can get about 3/16" maybe just shy of 1/4" of total play by moving the shaft firmly, but not "torqueing" on it either. I would like to measure the OD of a new yoke to see how it compares to the 1.5" measured on mine.
More testing today... I had been through this last year, but decided to break it all down again. wheels up supported by diff, I did the following:
--Normal
--No wheels
--No drums.
--with no drums, moved the pinion angle up & down a few degrees.
With all of the scenarios, I can get the pitch of the vibration to change, but it never goes away. Always comes on around 60-65, and real steady and more noticeable from 70-100.
Next step I think is "Proven Force", which is our local driveline shop where the shaft was balanced last year. I may just go through the whole drive shaft with new yoke, etc, that way I can get the correct ujoint on the differential side, instead of the Pontiac-to-chevy style, and I will know what I have, instead of the PO's mess.
Old 07-04-2014, 03:32 PM
428GTO70's Avatar
428GTO70 428GTO70 is offline
Send a message via MSN to 428GTO70
I know and that was my point, he said he is moving it around installed.
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi.
Everything installed, fired up and tuning has begun!
Old 07-04-2014, 03:35 PM
428GTO70's Avatar
Yeah to me that sounds like way too much play
Old 07-07-2014, 05:12 PM
leeklm's Avatar
Quick update... Brought the driveshaft in. Showed the tech a video of me moving the driveshaft while installed. He brought out a trans shaft, and then noticed my yoke splines had a twist about 3/4 of the way back.
Sales desk just called me back to say the shaft was way out of balance, needed the new yoke (which I planned on) and two new ujoints. About $200.
I suggested I had no issues with this at all, but why was it delivered to me in this condition last year from their shop after a standard balance? His comment was "no way did this shaft leave our facility in this condition". As I mentioned, my company does a great job as well 99% of the time, but there is always a case when someone having a bad day screws it up. He agreed and of course we moved forward with repairs. If what he says is true, I can only assume the previous guy spun it up and balanced as-is, similar to balancing a bad tire mounted on a bent wheel. you can balance it, but the end result is still messed up. (only guessing here)
As mentioned earlier in this thread, I have always had the vibration, even after the last balance. BUT, I will be very happy if this takes care of the problem!!
Wish me luck!
Old 07-07-2014, 10:44 PM
428GTO70's Avatar
Good Luck! I hope you got it all worked out.
Old 07-07-2014, 11:03 PM
grandville455's Avatar
grandville455 grandville455 is offline
Awesome Lee!!, Sounds like u found it!
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 07-08-2014, 12:50 AM
1969GTO's Avatar
1969GTO 1969GTO is offline
just listining in
color me gone
Old 07-08-2014, 01:40 PM
Qball's Avatar
Qball Qball is offline
Originally Posted by 1969GTO View Post
just listining in
Same here. Hope you have your solution.
Let me have a Diablo sandwich and a Dr. Pepper and make it fast---I'm in a goddamn hurry!
- Mike
1967 GTO
Old 07-08-2014, 10:14 PM
leeklm's Avatar
Default Hallelujah!!!
... and 3 amen's! Put the newly fixed drive shaft in and could immediately feel a difference in how tight the yoke fit in the trans. Spun it up on jack stands and while not as smooth as a modern car, much better (did have my drag slicks on, with not so perfect rims).
Took a test drive and wow, what a difference! Nice smooth ride, even at slower speeds where I did not think I was feeling the vibration.
I wonder, as it relates to my recent chassis dyno results, would a driveshaft this out of whack impact my HP numbers to any noticeable difference?
It is frustrating that the first guy to balance the drive shaft last year gave me a POS. I have spent hours tracking this issue down but on the bright side, I am sure I learned a few things along the way. I am just happy that it is fixed!!
Thank you everyone for the feedback and advice!
Old 07-08-2014, 10:22 PM
Blued and Painted's Avatar
Blued and Painted Blued and Painted is offline
Now im thinking I need a new drive shaft.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk
Old 07-08-2014, 10:57 PM
428GTO70's Avatar
Grats! I knew that sounded like too much movement, glad it worked out for you! You going to have the car at Car Craft?
Old 07-08-2014, 11:15 PM
leeklm's Avatar
Crossed my mind, but that event always looked like a pita to have your car at... Have you done it? I do hope to get out to Rock Falls this wknd for a couple of runs.
Old 07-08-2014, 11:53 PM
428GTO70's Avatar
Yeah I plan on bringing my GTO. As long as your car can handle idling through the fair for an extended amount of time in potentially hot conditions to find a place to park you should be fine. There's a lot of nice cars to see, its fun to bring a car in....pack a cooler make a day out of it.
Old 07-09-2014, 12:54 PM
PMD1969's Avatar
PMD1969 PMD1969 is offline
Did you drive it up to 65-70mph and note any change?
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213)
99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale
http://sohcsix.yuku.com/forums/1/OHC-lounge
Wanted: 1969 OHC "H" Camshaft
Old 07-09-2014, 01:19 PM
leeklm's Avatar
Got up to about 80 and yes, noticed a BIG change for the better.
