Old 02-21-2015, 01:41 PM
winger514 winger514 is offline
Default Canister photos
#1 is the OPGI repro; #2 & 3 are from the eBay ad for the 1961 I mentioned; #4 is from an old ad I found for a 1964 GTO canister; #5 is a canister currently on eBay as from a 59-60 SD (and is very similar to one I have)...
ID:	390867   Click image for larger version
Name:	61 canister.jpg
ID:	390868   Click image for larger version
Name:	61 Catalina canister.jpg
ID:	390869   Click image for larger version
Old 02-21-2015, 01:43 PM
Stuart's Avatar
Stuart Stuart is offline
Originally Posted by winger514 View Post
I found a photo of a canister on a 1961 Catalina on eBay (ad is ended). This car was advertised as the only known 4 Dr, 4 spd, tri power car. It did not have PS, PB or AC, so I don't know why the canister is there.
In 1961, tripower cars all had vacuum actuated linkage, mechanical linkage was only an over-the-counter option. As a result, the canister was needed for actuation of the linkage. (My car doesn't have power steering or brakes either.) I think this was the case for other years as well.
Old 02-22-2015, 10:24 AM
Default And I just keep learning more
Didn't know vacuum linkage was standard on ALL 61 tripowers. Here's a couple of pictures of my car from the early 90s. (it hasn't been out of the garage since 1994). Car still looks as good, sure wish I did
Old 02-22-2015, 10:26 AM
Hmmm,. only one photo uploaded,, here's the other one
Old 02-22-2015, 10:31 AM
Default Damn computer
One more try
Old 02-23-2015, 03:35 PM
cat1962's Avatar
cat1962 cat1962 is offline
Pictures of 61-62 and 63-64 can locations
ID:	391131   Click image for larger version
Old 02-23-2015, 11:10 PM
thanks....the 61 example is from the same 61 4 dr I also referenced. I can tell it's the same car from the rubber piece on the left snorkel to keep it from rubbing on the incorrect upper radiator hose and the stamp on the firewall above the steering column. You picture is better than the one I found, showing the mounting bracket going around the can, rather than being attached (2 separate "feet") on the bottom like the one I have. I showed the can I have with someone who has a 59-60 unit and he says they are different. After looking at your 63-64 example I now tend to think that is what I have. The same guy says he will send me good photos of a 62 canister. If so, I'll post it.
Old 02-24-2015, 10:12 AM
Engine-Ear's Avatar
This reminds of another situation where two part options were both correct.
Different vendors/suppliers, different final assembly plants, production deadlines all conspire and cause variations.
Old 02-24-2015, 11:44 AM
cat1962's Avatar
The reason these cans are mounted different is because the fender skirts are different.
See post #12 compared to 63-64 in post #26.
Old 02-24-2015, 11:48 AM
You got it. And every plant does things differently. As part of my job, I visit vehicle assembly plants and I know, first hand, there is NO absolutely correct way to assemble a car. It varies with time built, worker, available parts, etc.
Old 03-13-2024, 10:30 PM
GEM GEM is offline
Default GEM
I have a unmolested 62 Catalina Tri-Power, 4 speed with standard brakes. I want power brakes. I finally found a 62 factory booster but now need a vacuum canister.
Does anyone have suggestions in finding one?
Old 04-02-2024, 09:13 PM
mgarblik mgarblik is offline
I recently purchased one from this forum by placing a wanted ad. Had a very nice one on my door step in about a week. Reasonable price too. They are out there. 61-62 are the same. Little square canister.
