Old 02-25-2015, 09:08 AM
notime's Avatar
notime notime is offline
Yes, 70-72 with red line is the majority ive seen. However the GTO hose and the TA hose is slightly different and I am getting those now. Have the GTO hoses in stock.
WWW.SUPERCARCREATIONS.COM
Old 02-25-2015, 07:11 PM
transam1972 transam1972 is offline
Default ORIGINAL REPRODUCTION HOSES
for the most part I never considered this (n.o.s., repop ,) just need a replacement hose...but after seeing one on the 165TH car..I want one..I suppose its that yellow pinstripe
Old 02-25-2015, 09:36 PM
notime's Avatar
For the 71 Trans ams there is an early and a late date. The originals I copied from had a 69 date code on them and I also made up a later date on some of them of July 70 for the later cars and up. At this time Chuck Henley still has a few left of the batch I made in the NOS material Gates hoses. These pictures are them. When his are gone I will have more ready.
ID:	391339   Click image for larger version
ID:	391340   Click image for larger version
Old 02-25-2015, 11:58 PM
bossbirdta's Avatar
bossbirdta bossbirdta is offline
adding another fly in ointment; fortunately both My V.N. built 71's have their build sheets intact, one being a pretty early build (08) and the other later on (02) and both show the exact same two letter codes in their respective box's for the hoses which correlate back to that 3115 number for the upper....not to mention the photo I posted earlier of the 04 built car with what looks to be its as-built-with 3115 upper hose.....in all these examples it appears that NS is correct for at least 1971 and maybe a bit beyond that. ....
Name:	build sheets.jpg
Old 02-26-2015, 07:46 AM
necdb3's Avatar
necdb3 necdb3 is offline
Late 72 Trans am also shows "NS NT" on the build sheet.
Old 02-26-2015, 06:34 PM
notime's Avatar
Maybe its just a Van Nuys plant thing. Anyone else want to chime in with their original hoses? Maybe I will do them too but need to find out more about em.
Old 02-27-2015, 12:25 AM
bossbirdta's Avatar
not necessarily. after 1971 all Firebirds were built exclusively at the Norwood plant, until the end of 1977 I believe....
Old 02-27-2015, 10:01 AM
notime's Avatar
Well, all of the survivors and original hoses I've seen are the ones I'm making and were mostly Norwood cars. So I think the majority would have this hose and im sure the Judges wouldn't points off for it either way. If I get a large request for the one you have maybe I can do it but like I said, its probably the minority because there were different suppliers.
Old 03-02-2015, 11:31 AM
notime's Avatar
I now have a set of nos upper and lower 1970 Trans Am rad hoses in my possession. I will be making stamps this week.
Old 03-02-2015, 12:01 PM
Judge273's Avatar
Judge273 Judge273 is offline
What judging standards do you address?
The Norwalk?
TA Nats are more of a beauty contest..
Mike/Illinois
Old 03-02-2015, 02:31 PM
notime's Avatar
Not Norwalk LOL, that's a joke. Hopefully the TA nats will get up to speed one day, I know their working on it. As far as GTO nats, POCI and MCACN go, these should pass.
Old 03-11-2015, 02:02 PM
notime's Avatar
I've hit a snag on the lower hoses. Cant find a supplier with the original shape hose. Anyone have any idea where to get them?
Old 03-11-2015, 03:31 PM
Transamric's Avatar
Are there any Goodyear hose retailers in your area? Last time I checked, those were fairly close.
Old 03-11-2015, 04:20 PM
notime's Avatar
Fairly close doesn't cut it for me. I've gotten hoses from Dayco, Gates, Goodyear and AC delco and one other off brand and none of them are the correct shape. They will work but whats the point of doing concours correct hoses if their not shaped properly? The Parts Place had 2 listings a few weeks ago on ebay with both the correct and incorrect shape but the one with the correct shape in the pic is gone now so im not sure anyone can even get the right ones anymore.
Old 03-11-2015, 09:30 PM
Transamric's Avatar
What's wrong with the Goodyear hoses? Could you post pictures comparing a current Goodyear with an assembly line original?
Old 03-12-2015, 09:16 AM
notime's Avatar
I have sent all of them back so I don't have a picture but their not close enough for concours judging, the shape is just not the same, they are kinda goofy looking. Here is an nos one.
Old 03-16-2015, 02:58 PM
Default upper hose
NOTIME..I am a little slow...are you selling 1972 upper radiator hose with the markings for a T/A and what hose are you using...close enough is fine as are you saying they do not make an exact repop?...I recently got one from AMES so that is wrong regarding shape? ...I DO LIKE YOURS AND IT WOULD LOOK BETTER!..can you PM a total price..thanks!!
  #38
Old 03-16-2015, 03:38 PM
notime's Avatar
These are an exact replicate of an original, if you look back at the pictures, 1 of them is an original. However, Chuck Henley still has a few left in the NOS Gates hoses that I did for him, you will need to contact him to get an upper. When he runs out, I will be selling mine. That was our deal, we kinda did this together.
  #39
Old 03-16-2015, 07:33 PM
Default HOSE
THANKS!!...when you say N.O.S. most likely an expensive item...sounds like I will have to live with all black for now...and when all the N.O.S. are gone how about a close enough repop!??...thankx & T/C
  #40
Old 03-17-2015, 07:36 AM
notime's Avatar
The price for either one is $100 for the upper. I was just saying that the ones chuck has is in the original rubber material that I striped and stamped, they look like NOS. Get em while you can.
