paint and lacquer thinner? fine sandpaper?
![]() 1973 Formula SD455 - #'s auto orig paint 1972 Trans Am - 4 speed orig paint 1974 Formula 400 - Ram Air automatic 1966 2+2 convertible - 421 4bbl automatic 1967 Grand Prix - 4 speed orig paint 1967 GTO - 4 speed orig paint 35k orig miles |
Mike/Illinois |
Yes, drops of thinner, misting, wiping, re spraying...I give the credit to steve Schappaugh, who was able to achieve this effect. But first, I used all my original engine accessories, just cleaned them up. They have the original patina of age. I was hesitant when I first saw it outside of the engine bay, but now that it is placed, it looks right.
I'm going for what I call a restor-vation on my car. Trying to preserve as much as I can, and have one repaint. I've recently come across this group: Vintagecertification.com where you can be judged out of 5 areas of originality. Mine won't qualifiy for the exterior portion, but they have different levels of certification, so that's great you can still be judged. I'm not touching my trunk, underbody and have over 80% original interior. Going to have it done at MCACN.
Pat Brown |
![]() Quote:
interesting thread...definitely leave them alone..if possible leave it all alone and just paint the outside...you see when I got my car it had a funky silver repaint that seemed to be everywhere (I can still find traces of it)...I was so annoyed that it was all in my jambs and I most likely would never had thought color change (white instead of blue)...if I HAD IT TO DO all over again could I have gotten the silver overspray off??...I recall lovely Lucerne blue paint when I removed the fenders...but the jambs and doors and hinges were covered...I believe I tried and then (this was 1990) I said...I will just go to the local PONTIAC dealer and order all new parts and not deal with it..actually removed the door skins and had them dunked in PA, REDI-STRIP....anyway I do still have the factory blue everywhere else so save what you can cause its 2015
So what's the technique that won't leave a tape line in the jamb or the fog of overspray in there?
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
Mike/Illinois |
good question...
mask the heck out of the car...so what if you do have a tape line?...preserve what you can if that's what you want..for me its too late on the front cowl...but not the under body or in the rear wells or the metal package tray...even if you cannot see it, you just know its there...frame offs lose this but that's a different game (kinda like starting from scratch)
![]() Quote:
It's call burning in the paint edge. Lacquer is easy. B/C is a little more difficult. Lacquer will burn in easy if you put lacquer over lacquer. You have to use blending solvent on B/C. Not easy to do. If you spray B/C over lacquer the jams will never blend out perfectly.
White/Blue 71 455 HO T/A Auto Blue/Blue 71 455 HO T/A 4 Sp White/Sandalwood 71 455 HO T/A 4 Sp White/Black 70 RAIII T/A M21/373 (stripper) Carousel Red/Black 69 GTO Judge 4 Sp 2002 Firehawk Red/Black 6Sp Last edited by skunkwerks; 03-17-2015 at 01:01 PM. |
If you're able to do it without tape lines then I'd keep the jambs original. Tape lines kill it for me.
![]() Quote:
![]() That picture doesn't show anything very well at all Mike. ![]()
They did a scuff and paint with B/C and left Jambs, trunk, fenders infers.
The end results is straight sheetmetal brings with a new skin... ![]()
Mike/Illinois |
![]() Quote:
I get this burning the edge that they are talking about...I would work out the details with my paint person regarding this as what type of paint will be used on your car...since I am old I like what was originally used, lacquer..it can be worked with and is forgiving..again mixing new & old and a tape line is visible...that will explain the original paint next to the new paint
