EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
Especially when its 100% do it yourself and a pesky bill paying buisness is always in the way
Naa
I would have had that knocked out in a week |
Mine too, but I'm planning on finishing a couple little things today before taking it off of the jack stands. It's been out of action since the fall of 2012. I'm planning on testing Friday night with my new CVMS/H&M Airflow Dynamics ported E-head 467. Hopefully my old slicks still hook, and I'm not sure whether or not the new engine will like the old ethanol tune-up. I guess that's why they call it test-n-tune.
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
Check your wear indicators. I didn't do that for Pontiac Heaven and wasn't able to run as a result. I didn't realize I had so many passes on those slicks before I shut it down to do my blower conversion a couple years ago.
Jim
I have two sets and both have plenty of rubber, but they have benn sitting in my garage for too long!
Traction or not, I'm getting ready to burn some rubber! Oh yeah, my car is still on jack stands, I might have to take Friday off, so I can finish putting this junk back together.
I'm playing with a baby Poncho, and new-ish to the game. As a result I'm in a different category than most of you guys.
14.33 @ 96, at Pontiac Heaven on 4/18. Best time to date in my 67 FB. Jim, you were there. I will easily have 13's out of it once I get fuel delivery ironed out. The pieces are coming together, slowly but surely. New cooling goodies are en route, and I just got done ordering a new carb. Not sure when the next time I'll be at the track. Summer out here in AZ is sorta like winter in other places. I scale back a little due to the heat.
Jim
I finally got mine out for test and tune. Just have the street engine in it. No clean runs. Rev limiter comes on early, linelock wouldn't hold it so no transbrake starts. Shifter wouldn't shift. 5.90 1/8. 80mph
Combo?
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Holley Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
5.90@ 80 ???
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
Turbo 400 wouldnt go into 3rd. Had to let off. Light car maybe 2500 lbs with driver. Pump gas 535. Small cam 259/268 I think about 700 lift. HP heads 10:1 compression. Unported victor intake. 1050 carb 91 octane.
GTO George |
What would it normally run with this combo? Send a picture of the car.
Steve |
Should be a terror with the bugs fixed. Is it still white?
still white. Replaced everything else.
#38
My junk went to the body shop for a little bit. I swapped converters and picked up a bit, which I figured I would.
Went from this..... To this... We have a 3 day 10K race next weekend to get our summer started. Car was really good last weekend, driver not so much. Guess we will go chase it! |
#39
nice
#40
Greg Weigart IAIIA 520/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radial Pro/3300lbs/1.35 60'/6.21@110.47/9.77@137.08 Hot Rod Drag Week finishing averages: 2014 - 11.12 @ 118.56 2015 - 10.84 @ 124.97 2016 - 10.56 @ 127.88 2017 - 10.29 @ 130.74 2018 - 10.29 @ 130.53 2019 - 10.16 @ 132.34 2021 - 10.09 @ 132.69 2022 - 10.13 @ 133.07 |
