SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference.
Prev Previous Post   Next Post Next
Old 05-08-2015, 08:11 PM
lugnutt's Avatar
lugnutt lugnutt is offline
Send a message via MSN to lugnutt
Default Built 462 with wideports
455 two bolt main with ARP studs
Just Block filled to lower water holes
New Lifter bore brace
Pontiac “N” Crank Fresh from Machine shop
ATI Balancer
SFI Flywheel with Arp bolts
New Eagle H-beam rods
New SRP .030 over pistons
Bottom end balanced and assembled by Jack Gaydosh
Custom Deep oil pan
Factory Windage Tray
New Melling Oil pump
Cometic Head Gaskets
New Cloyes Timing Chain
Solid roller Cam, with offset Crower lifters .440 lobe Degreed by Gaydosh
New Manley pushrods
Edelbrock Wideports 360ish @700 65cc Chambers (fresh, with new springs)
T&D Shaft rocker
Custom ARP Head studs to clear T&D shafts
Ported Victor (Port matched and clean up)
New Mezier Water pump
Moroso Vacuum pump
Custom Alternator Mount with Power master 1 wire Alternator
New Billet Crank mandrel drive
MSD Crank Trigger
Almost every bolt on the motor is ARP
Fabricated Aluminum Valve covers (Gaydosh Performance with “The Monster” script written on them)
Never fired, still on engine stand. Have not bolted on the T&Ds so there is on pressure on springs. Need to finish installing T&D’s, install intake and prime and fire.
10500 OBO parts negotiable
If its one thing I know, its..... Uhhh I forgot .
What do you mean I couldnt be the president of the United States of America, Its still WE THE PEOPLE, RIGHT!!
