ivory interior 721 buckets console 8 track white vinyl top body side mouldings (I would think that's gotta be rare) Am radio, rally 2's, door edge guards, soft ray glass all, custom trim, dual horns, custom belts, wheel moulding, a/c , lamp ashtray, gto option and WW5.
Be sure to let us know when it hit's ebay. Does it have engine and drivetrain? I'm sitting here with a 455HO YB, TH400 and 12 bolt axle ready to go...
The first 455 HO YB engine 65 A, trim 721 (messed that one up) GTO I have noted is: -08D body build out of Pontiac plant. GTO, YB engine, console, AC, pwr strg, disc, fat Form wheel, big rear bar. IF its not a WW5 build, its another that got all the goodies. need to send off for PHS to note what I missed. Indiangiver68, can you post a pic of your '72's trim tag? Thanks. Have noted another Lakewood plant 65 A 721 trim build that is near identically equipped 455 HO auto, also a A105xxx build. Along with the AC Spark Plug Division car, all very similar,
Buzzards gotta eat... same as worms. Last edited by 'ol Pinion head; 07-08-2015 at 08:05 PM. |
IndianGiver 68 , thanks for letting us know about your car and sharing the Invoice with us for this Registry.
Yours is the earliest example , so far. Also added the MSRP prices for each car to the listings. $1012 Early Automatics 09/15/71 - VIN A105xxx = Invoice # 074151 = Fort Arthur, TX Sundance Orange / Ivory Buckets / White Top / AC *Earliest example , so far $5587 09/16/71 - VIN P?xxxx? = Invoice # 078327 = Flint, MI Sundance Orange / Saddle Buckets / Black Vinyl Top / AC / Cruise Ctrl. *AC Spark Plug Car , Acct # 60-206 $5590 09/24/71 - = VIN P109xxx = Inv# 096534 = Du Quoin, IL Silver / Black Bench & Column Shift / Black Vinyl Top / AC $5533 10/04/71 - VIN P114xxx = Inv# 116759 = Skokie, IL Lucerne Blue / Ivory Bench & Column Shift / Stripes *This car would be the "Low Price Leader" if it had been Invoiced later using the later price reductions. $4624 11/23/71 - VIN ?xxxx? = Inv# ?xxxxx? = Sedalia, MO Shadow Gold / Saddle Buckets $5332 $1006 Early 4 speeds 11/19/71 - VIN A130xxx = Inv# 233415 = Franklin, TN Red / Black Buckets / Stripes / AC $5467 11/20/71 - VIN P129xxx = Inv# 234050 = South Orange, NJ Sundance Orange / Ivory Buckets / Stripes / AC *Special MEMO Invoice $5308 $987 Later Automatics 12/13/71 - VIN P1xxxxx = Inv# 281914 = Penns Grove, NJ Red / Black Buckets / AC $5338 01/05/72 - VIN A143xxx = Inv# 315943 = Clark, TN WildGreen / Green Bench & Column Shift / Black Vinyl Top / Stripes / AC *Extreme Option Content - 2nd Highest MSRP , so far $5785 01/07/72 - VIN Z104xxx = Inv# ?xxxx? = Van Nuys, CA Sundance Orange / Black Buckets / AC *GMAD Company Car , Acct# 60-662 *Double Charged for LS5 455HO on initial Dealer Shipping Record $5430 (not including $134 overcharge for 455HO "option") 03/08/72 - VIN P166xxx = Inv# 465973 = Vermillion, OH Sundance Orange / Saddle Buckets / Black Vinyl Top $4996 ? / ? / ? - VIN P168xxx = Inv# ?xxxx? = Bellevue, WA Gold / Bench Seat & Column Shift (only have the Window Sticker Doc.) $4672 03/14/72 - VIN A171xxx = Inv# 480131 = Atlanta, GA Anaconda Gold / Saddle Buckets / Black Vinyl Top / AC $5431 ? / ? / ? - VIN A178xxx = Inv# 528623 = ?? , ?? ( only have upper 3/4 portion of Invoice ) Red / Ivory Buckets (AM radio, Console, Custom Trim,.. thats it.) *Lowest Option and Lowest Cost WW5 known , so far $4569 04/25/72 - VIN ?xxxx? = Inv# 574390 = Smyrna, DE Red / Ivory Buckets / White Vinyl Top $48x5 06/06/72 - VIN A210xxx = Inv# 668110 = Austin , TX Monarch Yellow / Ivory Buckets / White Vinyl Top / Stripes / AC / Cruise Control *Extreme Option Content - Highest MSRP , so far $6043 $982 Later 4 speeds 01/13/72 - VIN P146xxx = Inv# 336326 = Faribault, MN Lucerne Blue / Ivory Buckets / White Vinyl Top $4843 04/03/72 - VIN ?xxxx? = Inv# ?xxxx? = La Crescenta, CA Adriatic Blue / Ivory Buckets / AC $5445 04/27/72 - VIN A193xxx = Inv# ?xxxx? = Gaithersburg, MD Quezal Gold / Saddle Buckets (Only have the buld sheet and trim tag data) $ 4967 +/- = itemized using option data from Bsheet 06/12/72 - VIN P203xxx = Inv# 682341 = Corvallis, OR Sundance Orange / Saddle Buckets $4759 9/22/72 - VIN P142xxx = Inv# 740155 = Paramus, NJ Red / Ivory Buckets / White Vinyl Top / Stripes / AC Built Dec 71 - Sold Sept 72 *Car initially special ordered for EXPORT with ALL Seat Belts Delete *Eventually found a buyer in NJ - Built Dec 71 , Sold Sept 72 $5504 14 - Automatics 7 - 4 speeds 4 - Auto's with Bench Seat & Column Shift 8 - Auto's with AC 4 - 4 speeds with AC 6 - cars with Stripes Last edited by Baron Von Zeppelin; 07-08-2015 at 08:43 PM. |
By chance is his name Mike , in Missouri ? |
I just came across this thread and pulled out my PHS. It's strange because the WW5 option is $1039.51. This is a fairly early 11B build, auto w/ac. I will post the PHS for the registry tomorrow.
Thanks for putting this together!
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55 '72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80 |
No, the car is located in WI.
Here's the PHS for the Cardinal Red WW5 I bought a couple years ago. Not sure why the option is a different amount than what's been documented here?
![]() I'm at the Arthritis Foundation Auto Show in Columbus, Ohio today. An acquaintance of mine has his WW5 here that he bought new with 17000 miles. Sent from my iPhone using Tapatalk |
Probably a two page window sticker early 72 car too. More pix
Mike/Illinois |
![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk |
Get a picture of trim tag too. Interior shot too and is it a plastic rear valence? Original paint car too?
Mileage thing doesn't make sense has only 13k bought new at 17k?
Mike/Illinois |
Plastic rear valence was early in the year Mike - later ones should have the steel.
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
If original paint, get a picture of the decal on the trunk lid.
![]() ![]() He bought it new with no miles, it now has 17k+ miles Mike Sent from my iPhone using Tapatalk |
Thanks Doug, took me awhile... I was so impressed! Plastic valence?
Mike/Illinois |
Plastic
#38
Does the decal on the deck lid say "GTO" or GTO with a smaller HO offset below it?
Very cool car. |
#39
Thanx Doug, Got to get some interior pix for PB too!
Mike/Illinois |
#40
![]() ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk |
