Old 08-15-2015, 08:32 PM
grandville455's Avatar
grandville455 grandville455 is offline
Originally Posted by leeklm View Post
Front end height was bugging me so yanked the coils out. Found yet another reason why headers are a pain, as they interfere with the lower A arms when they swing down.
Cut just over 1/4 coil off, which lowered the car about 1/2". Would have liked just a little more, but not going to pull the springs out again unless they need to come out for another reason.
Here is a snapshot of the car. Pointed uphill a little, looks more level on a level surface. Good enough...
Looks Great Lee!!
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,[email protected]@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected]
M/T 275/60 ET SS Drag Radial
2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's
Old 08-15-2015, 09:28 PM
leeklm's Avatar
leeklm leeklm is offline
Thanks Darby! Was hoping to get out to rock falls this wknd, but again too much going on... It will be out there this year!!
Old 09-05-2015, 03:08 PM
Pontiac Performance Author
Cut 1" off the free length of the spring for 2" drop. People who have cut x # of coils and got good results are just lucky! Why ? different springs have different numbers of coils. A spring with 6 coils will drop the car further than a spring with 10 or 12 coils when cutting x # of coils. Keith S had it exactly right.
Old 09-05-2015, 07:17 PM
leekm Thats how my car sits right now with the factory springs in it. I wish I had the time to cut them down so I can get it lower in the front. I don't like looking at the car sitting on level ground & can see inside the engine compartment. Plus with the front up it slows you down because of the amount of air that can get under the car.
Old 09-05-2015, 07:45 PM
Alvin's Avatar
Alvin Alvin is offline
Question
Ken - have set of front springs on our '79 Trans Am WS6 Y84 4-spd purchased from HO Racing IIRC were supposed to drop 1/2 to 1" from stock IIRC - Yes?
I may still have the HO box in garage. These springs (HO Racing) are great enhancement of the factory WS6 coupled with the KONI Red Shocks.
If I wanted to purchase another set of similar front springs - where & what specs do you recommend I look for? Thx!
Old 09-06-2015, 01:12 PM
Alvin: Thank you.
Yes 1" drop.
I'll check Tue. to see if there is another set in the warehouse. I think there are a couple of sets of GTO springs gathering dust, but not sure on the T/As.
Old 09-10-2015, 06:08 PM
Alvin: As I suspected-no old stock.
Old 09-10-2015, 06:16 PM
Alvin's Avatar
Ken: Thank you for checking. Any idea on the specs?
