| THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
Maybe you can try it on the Dyno.
Greg Reid Palmetto, Georgia |
I've never understood the across the board % power loss idea. Everything the engine turns takes a set amount of power to turn it and that doesn't change regardless of the engine doing the turning, so the % power loss from accessories and other drivetrain losses will be less on an engine that makes more power. This is why it's a bad idea to install a TH400 and a 12-bolt behind a lawnmower engine...
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
We constantly have to make announcements over the PA reminding people to not run the AC while in the lanes, and if you enter the burnout box with water dripping, you will be sent right out the "breakdown chute" and not be allowed to make a pass. it's stupid and dangerous for the other racers as well as for yourself. Especially dangerous for bikes, as they tend to run a groove that is right where your AC condensate would drain to. As far as other effects, while Greg is correct that at WOT the AC clutch is cut off, few people realize that with many EFI systems, especially Ford EEC-IV, the tune actually changes with AC active, small timing advance is cooked into the calibration... This has been debated and proven, and a racer's trick is to unplug the compressor clutch and have the AC switched on on a run. Some swear it can add 10 horsepower... Seriously... .
GREG'S GOATS: 1970 GTO Judge RA-III, 4-SPD & A/C. Power Windows, Power Seat, Power Brakes, Steering, AM/FM, 8-Track, Formula Wheel, Rallye Gauges, Remote Mirror, Numbers Matching. Assembled at Pontiac, MI Plant 5/26/1970. 1968 GTO 461 CI, RA-III heads, Hotchkis springs, UMI suspension, Bilstein shocks, 12-bolt 3.73's. 1966 GTO Ragtop 4-Speed, AM/FM, Original driveline. |
A/C off when you race that green monster!
Not to mention that I think some of the old time magazine tests also ran a VERY loose alt. belt/power steering belts for the same reason.
Not sure if it is relevant to the topic, but just wan to add- I am running a Sanden compressor instead of the A6, and it draws lees engine power when the A/C is on...
