Old 12-03-2015, 08:19 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
All the 409 repop manifolds are in the $900-100 range-use Pontiac guys have been lucky!
Skip Fix
Old 12-04-2015, 07:41 PM
kathiek kathiek is offline
Default manifolds
Look like the same old castings from Classic Reproductions with the same CM in place of the Gm...ports are mediocre but they fit. If Ames won't handle the so-called "new" design then they are the same. oh well
Old 12-05-2015, 04:49 PM
njsteve's Avatar
njsteve njsteve is offline
Definitely not the same old parts. $359 for a 2-1/2" outlet manifold with ceramic coating.
None of the other brands come with a ceramic coating at no extra cost. I shopped around and the other versions charged at least an extra $200 for anything other than bare cast iron which makes a $400 set end up being well over $600.
They fit great and the car runs awesome. Massive difference in power compared to the factory 1975 logs I had on there and the restrictive parts store exhaust system from the 1980's. I am more than happy with my purchase.
Old 12-05-2015, 08:47 PM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
Default Great
Would like to buy if they come out or a 68 Firebird 400!!!
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, GM HEI and Ram Air pans and RARE Long Branch Manifolds
Old 12-05-2015, 09:11 PM
lugnutx2 lugnutx2 is offline
Other than the higher price, are there any quality control issues with the ones made by RARE? I'm getting ready to order a set of manifolds or possibly Doug's Headeders.
Old 12-06-2015, 09:25 PM
Hay, if you can get good ceramic for free...thats a deal. I got a bare pair. Compared them to our friends RARE pair they just received, ports weren't as good as RARE's and they weighed 10lbs more than the RARE castings. They also weighed 10lbs more than stock originals he had. Good Luck
Old 12-07-2015, 09:02 AM
I'll stick with the RARE. Thanks!
Old 12-07-2015, 11:44 AM
tempest1964's Avatar
tempest1964 tempest1964 is online now
Just curious, were these the newer version MAX/PYPES that Ccass referred to in post #3 or the earlier version that had some bugs?
Thanks,
Tony
Old 01-05-2016, 07:11 PM
jon greenwood jon greenwood is offline
Default Manifolds
Checked both sets @Ames last week. Pypes and there own. The casting was much better on the Ames set. More money but bought for my 65 as they will fit.
Old 01-06-2016, 06:17 PM
Default New RA exhaust manifolds
Stopped at Ames last week checked both sets. The Ames set more $s but had much better casting, so bought a pair and fit on my 65.
Old 01-07-2016, 12:31 PM
The Boss's Avatar
The Boss The Boss is offline
What's the point of the double post 23 hours apart?
And go racin' in the street.
Old 01-08-2016, 03:34 PM
crustysarge crustysarge is offline
Who was the guy in Dallas selling them years back? Probably 20 or so years ago I remember being on leave and buying a pair from at his house. He advertised in some magazines back then.
Old 01-19-2016, 09:22 PM
njsteve's Avatar
Pypes now has a sound clip of the system that was installed on my GrammaCar, on their website...well a little more than just sound......;-)
https://www.youtube.com/watch?v=ptAu...ature=youtu.be
Old 01-19-2016, 11:36 PM
sixty8ragtop's Avatar
sixty8ragtop sixty8ragtop is offline
Ram Air Restorations D-Port header feedback thread: http://forums.maxperformanceinc.com/...d.php?t=737036
1965 2+2 Convertible 421 HO 4-spd 3x2 8 Lugs
1968 GTO Convertible 400 AC Bench Seat Column Shift - Sold
Old 01-20-2016, 08:33 AM
The Boss's Avatar
Nice, looks like Paul Spotts marks are still there.
Here's mine with the Pypes exhaust system....no burnout, just a hint of what could be.
https://www.youtube.com/watch?v=mdw8viZ0dSk
Old 01-20-2016, 10:37 PM
Ccass's Avatar
Ccass Ccass is offline
Administrator
Per pair they may be 3-4 lbs heavier but the lighter weight is not magic. Iron is iron for the most part. There's just less material in the RARE manifolds. Unfortunately it's not taken from chambers where increased flow could benefit performance. It's mostly in the output ports where the gaskets can easily blow out because there's not enough iron for the gaskets to adhere to.
Everyone can brag about one vs another but the reality is all that is important is if they fit, flow and don't cost a fortune. Both brands were tested by HPP and they tested literally identical.
Link coming to some comparison picks.
Old 01-20-2016, 10:44 PM
Ccass's Avatar
Administrator
Just to be clear, there is nothing wrong with the RARE manifolds. Those manifolds have helped a lot of customers over the years. All I'm saying is that you now have another choice that is at least as good and about 20% less. That's why this is America.....you get to choose.
It just so happens that supporting the new Max Manifolds also supports 20 years worth of free Forums.
Available at Ames and NPD but you must request MAX or you may get CR manifolds which are definitely not as nice. (RARE are only available directly from RARE)
