Old 01-09-2017, 05:50 PM
62badboy 62badboy is offline
Do you possibly have a year model for that rim?
thank you.
Jim
Old 01-10-2017, 11:37 AM
Hello, Can you please measure the backspace on that wheel?
Much appreciated,
Jim
Old 01-10-2017, 11:53 AM
c5farmer's Avatar
c5farmer c5farmer is offline
Default mopar rims
Here are some pictures of the mopar rims. I did use a 1/4" spacer as can be seen in the pictures. P215/70-15 tires on a 63 Tempest. I didn't measure the bs, but it must be 4".
ID:	444610   Click image for larger version
ID:	444611   Click image for larger version
ID:	444612   Click image for larger version
Old 01-10-2017, 12:02 PM
Any part numbers that are available would be helpful.
I do appreciate the help gentlemen,
Jim
Old 01-10-2017, 07:22 PM
JohnFromVentura's Avatar
JohnFromVentura JohnFromVentura is offline
Ford Ranger rim:
Distance from mounting face to rear of rim: ~4 1/8"
Actual backspace is measured from mtg surface to inner tire bead so subtract 1/2" from 4 1/8" (this is often confused). I think all Ford Ranger rims are the same. I also think that I got the Ranger wheel tip from the guy at Skybird brake conversions? John
Old 01-10-2017, 08:43 PM
heater63's Avatar
heater63 heater63 is offline
Using them on my wife's 63 with Scarebird conversion. Works great. Don't know what year o mod l of Ranger but not sure it matters. As long as they are 15" and 5 bolt. Caps fit too
Heath
"If you aren't first, your last." Ricky Bobby 2006
