View Poll Results: Type of Camshaft in Your Street Pontiac
Flat-Tappet Hydraulic 166 49.11%
Flat-Tappet Solid 22 6.51%
Hydraulic Roller 106 31.36%
Solid Roller 44 13.02%
Voters: 338. You may not vote on this poll
Old 12-01-2015, 01:49 PM
A.W.Dille A.W.Dille is offline
Lunati BMII in the GTO at the present time. New engine will have a HFT Ultradyne 280-288 that I have been saving for several years. With slightly worked 670 heads should be nice street engine. Can't afford a HR so have to use what I've got.
1971 GTO,72 400, stock bottom end, 670 heads, Lunati BMII cam, headers, iron intake Q-jet, four speed. Best 60 ft 1.806in 2004. Best 1/8th mile e.t. 8.46 with 3.55 open rear
85 Grand Prix, 70 400, casting 62 heads stock rebuild, Turbo 350 trans 78 800 cfm Q-jet modified as per Cliff Ruggles book.
87 F350 6.9 4 speed dually
A poor man has poor ways.
Old 12-01-2015, 02:36 PM
ta man ta man is offline
"Old Faithful" Hyd roller from SD Performance in mine
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer
Old 12-01-2015, 02:53 PM
richardk's Avatar
richardk richardk is offline
Still running the HC-02 cam and Rhoads lifters I bought from HO Racing back in the '80s.
"I fishtail through the lanes, and I make my tires squeal.
Power at my feet, and glory at the wheel.
I wind the windows down, let the wind blow through my hair.
God knows where I'm goin' to, but me... I don't care."
Old 12-01-2015, 05:10 PM
East East is offline
Pontiac 9779068 as mfg by Crane Cams 1980s
Old 12-01-2015, 05:51 PM
David Jones's Avatar
Hyd roller with solid roller lifters.
Old 12-01-2015, 06:43 PM
Squidward's Avatar
Voodoo 702 in my FB with 350, Voodoo 703 in the 400 nearing completion for my Lee-mans. HFT's.
Old 12-01-2015, 07:11 PM
cnc's Avatar
cnc cnc is offline
SD's Stump Puller Hyd Roller with Solid roller lifters
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 12-01-2015, 08:57 PM
455rebel 455rebel is offline
Lunati
Hydraulic Flat Tappet Cam. Torque Monster for 400-455 c.i. daily driven street performance vehicle. Excellent torque and horsepower production with heavier emphasis on the low to mid range. Will work in tri-power applications with larger 389-455 c.i. engines. Choppy idle!
Advertised Duration (Int/Exh): 262/268
Duration @ .050 (Int/Exh): 219/227
Gross Valve Lift (Int/Exh): .468/.489
LSA/ICL: 112/108
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1300-5500
Includes: Cam & Lifters (#71951PR-16)
Part Number: 10510702LK
Previous Part Number: 60902LK
And it is a tq monster, pulls from idle to my current redline 5100rpm.
1970 amc rebel 4-door, faded blue paint,290 emblems on car, 455 under the hood.Turbo 400,3.15 gear.
Best so far 1/8 et,8.90 on street tires,
Since that I have added 400 heads.
I call it a rat sleeper.
Old 12-01-2015, 09:18 PM
ml3126's Avatar
ml3126 ml3126 is offline
Another stump puller hyd roller.
Old 12-02-2015, 12:19 AM
Chicagogoat's Avatar
Chicagogoat Chicagogoat is offline
Lunati Voodoo HF 705 cam (previous part# 60905) in a .035 over 455 w/Rhoads and Harland Sharp 1.65 roller rockers
Advertised Duration (Int/Exh): 284/292
Duration @ .050 (Int/Exh): 241/249
Gross Valve Lift (Int/Exh): .527/.548 w/1.5 rockers
LSA: 110
Old 12-02-2015, 02:21 AM
Formula8's Avatar
Formula8 Formula8 is offline
I really liked my 60310 SFT but recently swapped it out for an "old faithful" clone from PKMM. Saving up for a set of Crower solid roller lifters w/HIPPA. Hope to be up and running in the spring.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
Old 12-02-2015, 07:58 AM
74Grandville 74Grandville is offline
summit 2802
Old 12-02-2015, 08:16 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
HR, Comp 236/242 dur, 520/540 lift
Old 12-02-2015, 06:56 PM
Bobs78TA Bobs78TA is offline
UltraDyne Hyd. Roller from Bullet Cams.
Old 12-02-2015, 08:08 PM
geeteeohguy's Avatar
Flat tappet hydraulics in both GTO's: Sig Erson HI Flo I in the '65 since 1981 and still going strong, and a Melling 068 in the '67 since 1990 and still going strong. Both USA made cams and lifters, before quality went down the tubes.
Jeff
Old 12-02-2015, 10:26 PM
vtxman's Avatar
vtxman vtxman is offline
I have an HC02, a couple of 2802's and an Old Faithful Hyd Roller.
79 Trans Am 400 4 spd WS6
68 Firebird 400 Convertible
70 Pontiac GTO
2007 Pontiac Solstice
Old 12-03-2015, 09:06 AM
71 Goatman's Avatar
71 Goatman 71 Goatman is offline
Using HFT Bullet #307000 234/[email protected]
71 Goatman
Hot Rods & Horsepower.......A diease for which there is no cure.
71 GTO, 463, SD 295 d-port heads, 10.75:1, RPM intake, 502hp/560tq @ the crank, 200r4, 10" Continental convertor, Bullet 234/244 cam, Cliff's Q-Jet, 3:42's w/Eaton True Trac, 5 Power Tours. New performance numbers coming
  #38
Old 12-03-2015, 09:35 AM
GTO JONES's Avatar
GTO JONES GTO JONES is offline
Comp Solid Roller, duration at .050 269/279, lift with 1.65 roller rockers .719 / .727, 110 lobe separation.
  #39
Old 12-03-2015, 11:29 AM
stickboy's Avatar
stickboy stickboy is offline
Comp XE Solid roller 242 248 on 110LSA. Right around 600 lift.
Previously ran the old HFT UD 280 288 on a 112 - great street cam.
65 GTO, 3800#, 474, KRE Dport 330 cfm, 11:1 on pump gas, XE 242 248 solid roller, T56 trans, 3.90 gear, 11.26 @ 124 mph
  #40
Old 12-03-2015, 12:31 PM
Jc68fbody Jc68fbody is offline
Comp Xr 288hr 236 242 ground on a 112 lobe for supercharger..
