Old 03-28-2016, 11:20 PM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
Good luck MD79TA on the 68 Vert, also Congrats on your retirement!! If you can, could you post some pics of your progress along the way. Most of the folks here can tell you where parts and bolts go if you cannot remember. Even though I take pics prior to teardown, bag and tag, I always find something I laid down till later and then forgot about. I usually bag it as unknown and 9 times out of 10 find out where it goes by process of elimination. Having lots and lots of reference pictures also helps. Looking forward to following your progress.
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
Old 06-18-2016, 05:30 PM
MD79TA MD79TA is offline
End of april will be end of June. New M and H wire harness in all wired she turnover today just held back starting to a few things get tighten up. Will have motor running tomorrow then front bumper and fenders and I m off with it for the summer can't wait. I won't be the best looking yet but she's going to go like hell with 460 lbs of torque at 3200 rpm. Doug
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
1979 400 Block, 1970 Heads, Unknown Cam, Comp Cam Lifters, Edelbrock RPM Intake, Hedman Headers, Holley 750 Carb, WFO Drop Base SOLD
1968 GTO convertable project. 400 auto with air. west coast car . Not started in 15 ..update now running (around block spinning tires all the way. Have a lot of cosmetic work to do winter of 17/18
1969 GTO 400 4 Speed this a complete project. Rebuild will start in spring of 2017. SOLD
Old 06-18-2016, 05:53 PM
Nice!
Not sure how you wired the Starter, but I'm all for a separate (ford style ) solenoid
Old 06-18-2016, 06:53 PM
Not sure what you are talking about? Doug
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 06-18-2016, 07:28 PM
Had m and h harness purple to S solenoid ran battery hot cable to battery post on solenoid and the red wire that went from alternator to solenoid through the harness to the same battery terminal . that's it . As far as I know looking at every diagram I can this should be correct . Did not use the. R terminal ? Not sure what would goes there on Pontiac . Doug
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 06-25-2016, 09:33 PM
Big step today bought RARE manifold 2 1/2 with mandrel bent pipe from him they are going on tomorrow , here a quick video of start up today it close https://youtu.be/XezoiKwlBmU
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 06-26-2016, 05:09 AM
dataway's Avatar
dataway dataway is offline
MD79TA .... you are fighting the good fight bro, been following you for a year now I think. Hope it all works out good for you.
Old 06-28-2016, 12:47 AM
Guys on the last step to get this on road for summer. My plans are to put back together and drive for a few summer month then start on body work. My question is to every one who owns a 68 gto convertible as close to original with hide always and factory ac. I have all the restoration books but I'm looking for as many picture of engine bay as possible . Also any of how the front bumber and hideaway set up is bolted and vacume line run. I'm am going to include my email address to make easier for anyone who is willing to help . It's come a long way and that is only because of a lot of folks on this forum . Thanks in advance and I will take any and all pictures of the 1968 gto convertible factory ac car. Thanks in advance. All I have left is the inner and outer front fenders and the whole front bumber assemble .front core support is installed with new bushing. Thank you in advance Doug . [email protected]
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 06-28-2016, 03:22 AM
Scott Thelander's Avatar
Default here is a few pictures
of a couple fairly original enduras with hideaways
one of my 69's and one on a 68
the hoses get wrapped around the headlight harness
and up to the firewall ....
Scott
ID:	431659   Click image for larger version
ID:	431660   Click image for larger version
ID:	431662   Click image for larger version
Old 06-28-2016, 09:18 PM
Scott thank you guys please help me out with any pictures you have under hood and the front bumper and headlight assemble 1968 but sure 1969 is close if not the same . I learn a lesson that I will not repeat in taking more pictures before pulling everything out Doug
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 06-29-2016, 12:25 AM
dataway's Avatar
I've got a complete 68 hideaway bumper in my shed ... pretty sure it's mostly unmolested .... I'll take a look.
Do you have a 69 assembly manual? Pretty good for getting the routing on wires and hoses even for a 68. Usually very close if not the same.
Sure wish someone, somewhere could find a 68 assembly manual .... I guess it possible they never produced one ... but being a completely new model you'd think they would have had to. It would be worth a fortune if anyone could ever find one.
Old 06-29-2016, 01:33 PM
No if you think it will help I will get one . Any where you know sell them ? Doug
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 06-29-2016, 02:36 PM
ts3189's Avatar
ts3189 ts3189 is offline
I have a 68 in Middleboro you are welcome to come look at if it helps.
Old 06-29-2016, 02:50 PM
Ts3189 pm sent
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 07-28-2016, 08:02 PM
Well thing are taking longer than we thought. This was our first rebuild and one thing I learned is you can not tag and bag enough. Filling a bag and calling it front bumper does not work. Pictures pictures and more pictures tags and more tags you just can't take enough time to do this lesson is learned. But with the help of a lot of forum members and and my son with most of the hair I had left it is within a few hours more hours of labor of hitting road. We are proud that we have done all of the work ourself. I will be doing body over this winter but my plan was to get a few month of driving this year and I think that will begin next week. Thanks to all who helped will send some pictures as it hits the road. It looks the same on the out side but when you put the hood up better than new. Again a thank you to all that have helped . Doug
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 07-29-2016, 07:56 AM
ts3189's Avatar
Smile
looking forward to seeing it doug.
Old 07-29-2016, 12:41 PM
Might take a couple of weeks need a few parts I just ordered . Thanks Todd for your help
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
