Old 04-26-2016, 11:07 AM
The price structure of the Safe-T-track is the same as on the A, G and F bodies; $42.13 for standard STT and $63.19 for HD STT. The cutoff was by gear ratio only; 3.23-3.36 with 3.23 or lower numerically being $42.13 and 3.36 and up being $63.19. With 3.90 or numerically higher STT became mandatory. On the big B cars all STT's are the same price regardless of gearing; $42.13.
In terms of actual physical content I know that 3.23's on the G used a 4 pinion with STT or open diff unlike the A or F cars which used a 4 pinion only on the 3.36 and up. It's been many years but I seem to recall that while studying the MPC that only the GP could be had with forged axles which only came with 3.90 and up if I recall correctly.
Old 04-26-2016, 12:37 PM
bulletpruf's Avatar
bulletpruf bulletpruf is offline
Forged axles came in GTO/Lemans 8.2's as well.
I thought that the HD-STT meant 4 pinion, N-case, and forged axles, but never pulled my 3.55 HD STT rears apart to check. My 4.33 rear (1970) was forged. I have a 3.90 rear in my 68 'vert, but haven't pulled axles from it.
Scott
Please check out my YouTube channel for vintage/classic car and truck builds and shenanigans! https://www.youtube.com/watch?v=jq61KxKp1Is&t=14s
Old 04-27-2016, 10:33 PM
Bet Winner's Avatar
Bet Winner Bet Winner is offline
Originally Posted by bulletpruf View Post
Roger -
All good info. One point -- I had two 69 Judges with a 3.55 HD STT (both RAIII M20), unless my memory is failing. Never had the axles out on either, so not sure if they were forged or not.
For those following along - the nodular housing has an "N" cast into the top of the "nose" of the housing. Right above the pinion seal. You can't see it from under the car, but you can feel it.
Cast axles are constant diameter and smooth surface. Forged axles are tapered and rough surface.
Took apart one 8.2 that had one cast and one forged axle; not sure how that happened, but would be interesting if it came like that from the factory.
Scott
Years ago I took out the passenger side axle because the outside bearing was making a slight noise so I could have another pressed on the axle. The passenger side axle was forged--tapered and rough. I knew enough then to know the difference. The rear is a HD rear with the N cast on the housing. My Judge was built 01C in Baltimore. The rear end assemble date is the latest date code on my car. I have never had the driver's side axle out.
My Wife: "I thought I married a sophisticated business man, but what I actually got was a redneck fisherman with muscle cars."
Some people know all of their rights, but none of their obligations.
Old 04-28-2016, 12:33 AM
bulletpruf's Avatar
BW -
What gear ratio?
Scott
Old 04-28-2016, 07:27 AM
Bet Winner's Avatar
The "standard" 3:55. It is an early pattern 4-speed. There is no gear option.
Old 05-01-2016, 08:29 PM
I have a couple of 1969 3.23 limited slip rear ends, and they are 4-pinion posi units.
I have a 2.92 limited slip out of a GP, and surprisingly it is a 4-pinion posi unit as well.
Mike
Old 05-12-2016, 10:30 PM
bulletpruf's Avatar
Mike
Nodular housing or gray iron? Forged or cast axles?
