Old 05-05-2016, 11:01 PM
mechanickeith's Avatar
Originally Posted by roflo619 View Post
This is exactly what I was needing/wanting/hoping to hear! Thank you! Now to find a machine/brake shop that can do this for me the right way! ;-)
Look for an industrial brake shop. One that does brake & clutch rebuilding for heavy truck/construction equipment. They can handle it correctly. Here in the Phoenix area the only place I would trust for that type of work is Arizona Brake & Clutch.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 05-14-2016, 11:15 PM
jdh421's Avatar
jdh421 jdh421 is offline
Not sure of you have found hubs yet. the 65-70 front cast iron drum can be removed from the hub by simply pounding out the wheel studs. I have replaced many grooved or cracked used drums onto original hubs. you will need a new set of front wheel studs when you replace the drums. I have a couple sets of hubs if you are still looking for a set. email me at [email protected]
1966 Catalina Convert
1968 Firebird 350
1969 GTO
1967 Bonneville 4 Dr Brougham 428
1967 Bonneville 2 dr
1959 Buick LeSabre 2dr
