Ditto. A light car helps. 👍
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. ![]() Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
I have been racing pro trees for 5+ years. I race a 10.0 index with a .500 pro tree. You have plenty of time. Go on the 2-step as soon as the last person stages. Then get ready. You might have to bump in one more time for a good reaction time If you or the car react slow. I raced a couple .400 tree events and it was no different than the .500. On the .400 tree I had to launch at 4500 and one extra bump to get a good light. On the .500 I just turn on the stage light and launch at 3000 in the day and 2800 at night.
A pro tree is addicting. It will mess you up on a sportsman tree if you leave of the bottom bulb. |
Get on the brake when you turn on the stage light. When the second person stages, mash the gas and launch on yellow!
Back in my mud drag days, we ran a .500 pro tree and the entrance to the drag lanes was downhill. If you tried to foot brake and then hit the trans brake you would roll through the stage beam, so I always had to stage on the trans brake. With a 4500 lb 4x4 truck sporting 38 inch mud tires, there is plenty of lash in the transfer case that you had to really have to account for when you hit the button. With those large front tires, you really had to gauge how deep to stage to cut a good light. Try to do that when you have at least 8 inches of free roll when you hit the trans brake!
69 Judge convertible........clone! Carousel red, parchment, hideaways, TH400, 10" Continental 3200 stall, 12 bolt with 3.42, 469 c.i. with ported #48's, ported cast iron intake, Cliff's Q-Jet and ported 2-1/2" Ram Air manifolds. |
![]() Quote:
GTO George |
Good point George, some starters activate the tree way early and you better be ready for it or you will be late. Learn how they do it in time runs so that you are ready to rumble in eliminations.
For the bracket racer, be careful as that pro tree will seem really fast at first hit.
Dave Polichena |
Is it ok to just turn the delay box to zero or should I bypass the box by wiring the switch directly to the transbrake.
old combo 70 firebird 3250# race weight 462 #62 d-ports best 9.60 @ 140.20 naturally aspirated new combo 70 firebird 3280# race weight 523 HiPorts by EIC Motorsports 8.49@158.9 N/A |
Zero is okay
I think there is a auto switch on the light that is activated when the the second car in second bulb lights.The track has the option to turn it on or have the starter activate the light.Tom
Most tracks use the 'auto start' which does that, when 1st car stages, the second car has a set amount of time to stage then the yellow has a set amount of time to flash.
The yellow set time is usually random time in a range of time. (varies from manufacturers) Usually the Pro guys, (NHRA) the starter activates the button. (like Nitro classes) ![]()
