Old 08-21-2016, 05:54 PM
GREATGTO's Avatar
GREATGTO GREATGTO is offline
Motor oil is a coating, try running your engine without any and see if it makes a difference.
Car Craft Garage.
Automotive Restoration
Old 08-21-2016, 06:52 PM
mike leech's Avatar
mike leech mike leech is offline
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
Old 08-21-2016, 07:22 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Originally Posted by mike leech View Post
What do you expect.
First Pontiac powered street car in the 7's
[email protected]. 3460#s
Old 08-21-2016, 07:30 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
Originally Posted by LiL Jack View Post
What do you expect.
I expected a stupid answer from GREATGTO but damn the motor oil thing was the stupidest thing ever.
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 08-21-2016, 10:13 PM
Tom Vaught's Avatar
Boost Engineer
Motor Oil is a Lubricant, Motor Oil is a Coolant, Motor Oil is a Hydraulic Fluid, but Motor Oil as a coating, while true (it does keep parts from rusting), is way down on the list of what it is used for in an engine. I will give you a D-Minus for that answer, not an F but darn close to it.
Tom V.
Old 08-22-2016, 08:03 AM
Half-Inch Stud's Avatar
Thermal barrier coatings for combustion chambers: probably see a HP benefit with aluminum heads. Ping?
Friction reduction coatings; probably see a HP benefit in the rear gearset & transmission, maybe in the engine. Seems to mee that the high-loading surfaces are better-off with a polish and Redline lubrication.
Old 08-22-2016, 08:22 AM
mgarblik mgarblik is offline
Agree, the anti-friction coatings must do something, because almost all the OE's use them on piston skirts. They do it for mileage and emissions. Coating allows tighter piston to wall clearance which means fewer hydrocarbon emissions. Anti-friction results in less heat and more HP. The real question which nobody can put a number on, including the coating manufacturers and sellers, is how much HP gain. Is it 2 HP on a 1000 HP engine?, 8 HP? They never want to put a real number on it. Certainly isn't anywhere near 50 HP or as I said, sanctioning bodies would be all over it. We run "hard anodized" pistons in our car. That could be considered a coating, I guess. We do it to provide a greater margin of error in our tuning. The soft aluminum piston is shielded from melting a fraction of a second longer with the coating than without. Think of it as the difference between a regular fuse and a "slow blow" fuse. So in a sense it makes more HP by remaining a piston longer than a glob of melted aluminum. Coatings have their place in an engine, but there are many more cost effective places to spend $$$ first.
Old 08-22-2016, 05:32 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
You definitely can get coatings poor if you do everything.
Seeing sludge on windage trays and in oil pans even with regular oil changes I usually get mine teflon coated. Piston skirts since even Sealed Power coats them and piston tops. Usually bearings partly because mine sit for a couple of months before they get started and figure cold start it could help. It helps PolyDyn is local and I can drop stuff off and not have shipping costs. They do headers also now.
But the new 455 for the 81 got no coatings but the pan.
Skip Fix
Old 08-23-2016, 06:22 AM
mike leech's Avatar
With a micro polish and a coating coating like microblue on the ring gear and bearings it's possible to run thinner dif fluid. Possible help there.
Problem is pro stock re-Coats often I'm told. By a very reliable source.
EHTTFMF!
Old 08-23-2016, 09:48 AM
Mike, hmmmm, if your ring-pinion is still swimming in 80-90W then please look into draining it ut, wiping everything clean, solvent spritz, then reload with the Redline stuff. Definite reduced temperatures.
....and reduced parasitic HP losses.
Old 08-23-2016, 12:55 PM
chiphead's Avatar
chiphead chiphead is offline
What do you guys think of Swain's coatings for piston skirts to reduce piston to wall clearance?
Old 08-23-2016, 01:40 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Works great for that application.
Go fast, see Elvis!
Old 08-23-2016, 04:03 PM
Money Pit's Avatar
Money Pit Money Pit is offline
https://www.line2linecoatings.com
Check them out.
Old 08-23-2016, 06:23 PM
mike leech's Avatar
I'm running Dewco lube. If I didn't know better I would think it was 10 W 30. Super light weight
EHTTFMF!
Old 08-23-2016, 06:24 PM
Scott Roberts Scott Roberts is offline
I saw a commercial once where you could run slick 50 and drain the oil out of your motor with no damage....
Old 08-23-2016, 06:48 PM
Aaron Quinton's Avatar
Aaron Quinton Aaron Quinton is offline
The skirt coatings are there too reduce the effective piston to wall clearance while dealing with more bore distortion. It reduces noise without scuffing. That is it.
If you think about it, the friction in the power cylinder boils down to rings rubbing in the bore and the skirt to wall clearance shearing oil. Tightening the clearance up reduces oil film thickness increasing friction.
Agree, the anti-friction coatings must do something, because almost all the OE's use them on piston skirts. They do it for mileage and emissions. Coating allows tighter piston to wall clearance which means fewer hydrocarbon emissions. Anti-friction results in less heat ..
Old 08-23-2016, 06:56 PM
Check the Red Line stuff; likely thinner, likely slipperier, likely never get dark colored after many runs.
  #38
Old 08-23-2016, 08:24 PM
Tom Vaught's Avatar
Boost Engineer
Custom Lubes and Coatings have a place, putting them in the right places is sometimes a learning process.
Tom V.
  #39
Old 08-23-2016, 08:35 PM
So I shouldn't be running 80w 90?
1.079 4.52 155.15
3000 lbs
Special Thanks to:
Butler Peformance
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
  #40
Old 08-23-2016, 08:58 PM
PAUL K's Avatar
Yes....otherwise you'd be too fast because you have E-heads.
Go fast, see Elvis!
