As others have said make sure that your rubber fuel hoses from the tank are all in good shape. I remember once having this problem too, on another car. But that one would not run at all with the broken hose.
Both a cracked fuel hose and a bad pump can cause the same symptom- no gas gets in the carb when cranking.
1969 Lemans vert, matador red, 462 CI, 3.07 12-bolt posi 1974 455 TA, admiralty blue/red interior HPP "cover car" - sold "The best way to show a car is to drive it" |
![]() Why??? They were so hard to get to, generally the REAL PROBLEM was diagnosed and repaired before the carburetor was touched ![]() ![]() And Cliff, the foam pads actually did work, as least in the mind of some of the "mechanics" (nowhere else). Jon.
"Good carburetion is fuelish hot air". ![]() "The most expensive carburetor is the wrong one given to you by your neighbor". If you truly believe that "one size fits all" try walking a mile in your spouse's shoes! Owner of The Carburetor Shop, LLC (of Missouri). Current caretaker of the remains of Stromberg Caburetor, and custodian of the existing Carter and Kingston carburetor drawings. |
The fix ended up being a different choke rod and box. I picked one up for a 68'-70' from the parts place. Had to tweak the rod slightly. Works like it should now. Also found a loose distributor cap. (My father takes the blame for that one)
1972 Chevelle SS 2dr hardtop 454 LS5 4 spd - "Pure Stock" 1969 Chevelle 2dr hardtop L72/M20 - my "retirement" project. 1968 Chevelle 2dr hardtop 6.0/80E - pro tour-ish 1972 Monte Carlo turbo 6.0/TH400 2001 Silverado RCSS LQ4/80E swapped, cam, headers, FBO. 1972 E lCamino SS AFR headed 454/TH400 - the old man's project |
