73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 07-25-2017, 08:45 PM
77 Canamman's Avatar
Exclamation
Originally Posted by S Courter View Post
These cars are heavy and low on performance so probably will not run it at the PSMCDs although it would be fun to see how fast(slow) it is.
I weighed my low option '73 GTO 4 speed. It was 3700 and change. Not as heavy as some make them out to be. The same car with a 3.42 rear was a 14.90 car. Not exactly low on performance either. Maybe your car could benefit from a good tune..
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 07-26-2017, 08:31 AM
trishieldchief's Avatar
Yes, from Iowa. These cars are heavy and low on performance so probably will not run it at the PSMCDs although it would be fun to see how fast(slow) it is. May bring it up to spectate. It is a very nice car!!
Steve, that is a perfect PSD car being a 400 and no AC, hope you run it, look forward to seeing it ,looks great.
Rich Johns
www.purestockauto.com
1970 GS 455 M21 4 Speed 3.42
1987 GN Astro Roof
Old 08-18-2017, 06:25 PM
S Courter's Avatar
S Courter S Courter is offline
Here is another picture my wife took with a better camera.
Name:	73 gt 1st drive.jpg
Steve
71 Pontiac GT-37 400 4 spd (sold)
71 Formula 400 turbo 400 (sold)
01 Firebird T/A WS6 auto (fun)
64 Tempest Post car LS1/4L60E (Love It!)
65 Lemans Post car LS1/4L60E (More Fun)(sold)
73 Lemans GT 400/auto 1 owner 52k miles
69 El Camino LS1/4L65E (Awesome)
70 Pontiac GTO Convertible 400/400 Original (sold)
69 Olds Cutlass S W31 Numbers matching 4Spd 3:91 one of 569
72 Post Coupe GTO 400/400 1 of 60 built 1 owner original
Old 08-29-2017, 12:00 PM
jerry455 jerry455 is offline
When I had my Can Am I weighed it Milan Drag way and it weighed 4260 lbs with a full tank of gas. It was loaded with all power options.
Old 08-29-2017, 12:32 PM
moontower69's Avatar
moontower69 moontower69 is offline
Default Weight mystery
Wow, can power options really add 500+ pounds on one of these A-bodies?
It's always been a mystery to me what my 74 Lemans really weighs - some websites say they weigh 3700 or 3800 lbs (only modestly heavier than a 65-72 Lemans) and some say they came from the factory at closer to 4000 lbs (which would slow them down compared to the earlier A-bodies). Seems reasonable that the new 1973 EPA-mandated 5mph bumpers added a few hundred pounds but not a beastly 300 or 400 lbs??
Look at this sample data for 1973-74 Lemans/GTO:
Ultimate GTO website says 4044 lbs
http://ultimategto.com/cgi-bin/stats...1973&f1=weight
BUT many other sites SAY LESS w curb weight closer to earlier models:
3628 lbs.
http://classiccardatabase.com/specs....1974&model=344
Hagerty website says 3552 lbs
https://www.hagerty.com/apps/valuati...pontiac-lemans
3579 lbs
http://1976lemans.blogspot.com/p/1976_20.html
1974 Lemans Sportecoupe GT (daily driver)
.030 over 354, #47 heads (84cc), Lunati voodoo 700 camshaft (207/213 @ .050), logs, 2.5 duals, X-pipe and Dynomax super turbo mufflers, 3.08 rear
Old 08-29-2017, 01:00 PM
Grand73Am Grand73Am is offline
When comparing apples to apples, I'd think a 73 is a little lighter than 74-77 because the 73's were only required to have the 5 mph bumpers in the front, and not in the rears. It wasn't until 74 that they were required to have both front and rear 5 mph bumpers. So, the 73 rear bumpers were somewhat lighter than the others.
Steve F.
Old 10-20-2017, 04:06 PM
chicagoland chicagoland is offline
5 mph bumpers were heavy, maybe 80 lbs each, per some posts about the '74 GTO.
Old 10-21-2017, 11:03 AM
You have to keep in mind that that it isn't just the bumpers, its also the 2 shock absorbers that each weigh about 8lbs, all the extra mounting hardware, the brackets, the changes to the frame to fit all the parts, the bumper fillers and attaching hardware to make the car look somewhat better. Otherwise the cars would look like some of the AMC products of the era that have the bumpers just jutting out from the body. Just look at pictures of 74-76 AMC's to see what I mean. I can see an extra 200lbs for the 1973 model year, and 300lbs for the 74-77 model years. I don't know how much they had to strengthen the frame to meet the crash standards, of if they had to increase the gauge of metal.
Then you consider that most cars made in 1973 had A/C, power steering, power brakes and the increase in size of the cars themselves, I have no problem with the average 1973 car being 300-400 lbs heavier than the average 1972 car of the same model.
Old 10-21-2017, 11:17 AM
leeklm's Avatar
leeklm leeklm is offline
For comparison... I just ran my 73 GTO across the scales at 3,740. Here are the details...
--light weight weld wheels and bias slicks- total weight savings of 100 pounds over steel wheels and big rubber.
--aluminum heads and intake- at least 100 pounds lighter than iron
--Turbo 400
--factory non AC and non console.
--factory manual disk brakes and manual steering
Easy to see where a loaded car is well over 4k. I have had my bumpers off, and that front factory bumper is at least 100 pounds! The rear is maybe closer to 80 pounds.
While this car will pull the front wheels off the ground, I might need wheelie bars if I removed the railroad tie of a bumper!
Sent from my XT1585 using Tapatalk
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight
Old 04-04-2018, 10:08 PM
UPC-WU2's Avatar
UPC-WU2 UPC-WU2 is offline
Did you ever get a chance to get a pic of your PHS?
Originally Posted by GtoBrian View Post
I have the PHS will take a pic and get it posted as soon as i can.
1971 GT-37 - 350/M38, Rosewood Metallic/Black
www.GT-37.org
Old 04-07-2018, 11:27 AM
GtoBrian's Avatar
GtoBrian GtoBrian is offline
im sorry have not as of yet but will dig it out soon as i get a chance and post it, thnx for reminding me as i havnt been on here as much as i used too.
1969 Judge, Matador Red, Black, RAIII 4Spd, Owned 33years
1974 LeMans GT Honduras Maroon, 3 speed stick 350 2brl.
1963 Catalina 389 Black with Burgandy Ventura interior SOLD
1970 GTO Pepper Green 400 YS auto Factory A/C 56K orig miles
Old 11-06-2018, 01:02 PM
Scott Thelander's Avatar
Default 1975 Lemans GT parting out
hood sold
radiator stolen .... shroud hammered
all else complete
mouse infested under the hood interior stinks too
really good parts car ... straight body with rust around vinyl top
Scott
2zero6 465 9165 till 10 pacific time
ID:	497077   Click image for larger version
ID:	497078   Click image for larger version
ID:	497079   Click image for larger version
ID:	497080   Click image for larger version
Old 11-06-2018, 06:37 PM
muscle_collector's Avatar
what are hoods bringing these days
Old 11-13-2018, 01:19 PM
Pontiacdaver's Avatar
Pontiacdaver Pontiacdaver is offline
Originally Posted by Scott Thelander View Post
hood sold
all else complete
Scott
PM sent.
-Dave
2 wrongs don't make a right, 3 lefts do. 4 lefts make a NASCAR race but who cares?
2004 Grand Prix GT daily driver
1974 LeMans GT 455
