THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
In Australia is opposite and upside down. So turn it .......hmmm
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here Just Say No To 8” Flakes F ire B irds 🇮🇱 |
Damitall Burd, I forgot all about that. For you guys down under, just flip your car, or truck, over on it's top and you'll be sitting pretty much the same as us up here. LOL
Used this method today at my son's house. Worked very well. I have 3 different cap type wrenches, a strap wrench, and a three jaw type. Unfortunately, they are all 700 miles away and I wanted to change my oil before heading back home. Great idea Chris.
1961 Corvette 4spd. 1969 Chevy K5 Blazer - currently restoring |
The screwdriver would probably not work on a properly applied filter. It makes a great can opener on the very thin metal of the filter. I would bet that whoever started that suggestion probably never tried it out themselves.
Filter wrench?!!! Real man don't need no filter wrench!
the large screwdriver did work once for me on an olds engine back in the day. made a mess big time, but I got the filter off. those metal cups that fit on the filter work great. I just don't know why people install them like head bolts. 1 full turn after gasket seat is all I ever do and have never had an issue.
I have always used the wrench pictured below and has not failed but once. I have used the screwdriver before and it tore up the filter when I poked it to low. The key is to get it higher and if that fails you can use the below wrench at top of filter with a little sandpaper sandwiched between filter and wrench for more bite. Like zeebo said when putting filter back on there is no reason to over tighten with wrench or pliers. Let the filter make contact and turn by hand 3/4 turn or 1 full turn.
going bandit-Reynolds style |
This has taken every oil filter off that has attempted to stay on. http://www.lislecorp.com/divisions/p...n=1&category=9
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. |
I've never seen that- pretty cool
I have used a Hazet three fingered gear activated 'claw' for the past 30 or so years. Gets every stuck filter off with ease. Mentioned earlier in one of the posts. The harder you pull on it, the tighter it grips, and it presses flutes in the side of the filter and does not slip off.
Jeff |
- '67 GTO '97 993 C4S '86 951 '05 V70R |
The strap wrenches will eventually collapse and tear the sheetmetal just above the base plate on really stubborn spin on filters. The only alternative at that point is to use a hammer and chisel to start the base plate moving.
Most people reading this won't ever encounter a filter that tight, it does happen occasionally, especially with large diameter canister hydraulic filters. The hydraulic filter on my wrecker had been on there who knows how long and it collapsed and I had to remove it with a hammer and chisel. I've had a few oil filters in my years as a mechanic that could only be removed in this manner too. They were usually installed by the factory and of course the genius putting the oil filter on at the factory, will never have to remove it. |
i stopped in at the Eastwood Company today and saw this:
http://search.eastwood.com/search?w=...20wrench%20set it was almost too good to pass up. |
I bought an 83 VW GTI Rabbit new. Great car and a hoot to drive.
I did the first oil change myself and the car ended up going back to Roy Bridges VW on a wrecker on VW's dime after the filter collapsed as I attempted to turn it. I figured explaining this over the phone was going to be all ****s and giggles but the service folks were very responsive. I found out later that VW had had an issue with someone putting them on dry at the factory and this wasn't the first one they'd dealt with.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
David was that a VW filter.. or whatever they use at the dealer? When I change my oil I always add oil to the filter before I put it on. Unless it goes on sideways so you can't add oil to it. Like on my Kubota G2000 where the filter screws on horizontally.
I only use Wix, Purolator, and when in a bind.... Fram.
Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. Last edited by GT182; 04-14-2017 at 09:36 PM. |
I have had to use a another wrench to hold the metal body from spinning while I used a 1/2" ratchet to tighten the strap around the filter. The other trick is to put a zip lock bag around the loose filter, spin it off and let it fall into the bag, wait on minute to let oil drain from engine into bag, zip bag closed and remove. No oil covered headers! Someone on PY posted this and it works great.
"Artificial intelligence is no match for natural stupidity". 1966 GTO Post Coupe, 467ci. N/A Pump gas, best 1/4 11.6 118mph 1966 GTO Post Coupe, "The Bright Idea" 535ci. N/A Pump gas, best 1/4 9.58 141mph |
