National Events Events that normally draw audiences from more than a 10 state range
Old 07-19-2017, 01:56 PM
The Boss's Avatar
The Boss The Boss is offline
I like those too!
And go racin' in the street.
Old 07-19-2017, 04:34 PM
AMES-TECH's Avatar
AMES-TECH AMES-TECH is offline
Ames Tech Staff member
Originally Posted by flyingn View Post
we would have to be there, but we will be here instead
You know the AMES crew will be there!!! Best Pontiac show period... Not saying we don't envy flyingn though lol!!!! Don't forget to get those orders in!!!
Old 07-19-2017, 08:04 PM
63Banshee's Avatar
63Banshee 63Banshee is offline
I'll be there with a few guys selling parts and seeing about bringing the Tyree funny car next year. Come see us. Spaces 138-140 & 191.
Old 07-23-2017, 06:57 PM
1oldgoat's Avatar
1oldgoat 1oldgoat is offline
Here are some of the parts I'll be bringing to sell.
68-72 GTO rear lower control arms NOS
68-72 GTO Upper control arms NOS
72 GTO turn signal bezels NOS
TRW timing chain-new
pf30 oil filter NOS
68-72 door strikers NOS
AM/FM stereo 75-80 NOS
68-72 windshield washer nozzles
used left 71-72 GTO head light bezel
left 71-72 GTO headlight bezel NOS
68-72 Rally Gauge printed circuit NOS
Cable to mount clip NOS
70-72 rear bumper guards NOS
mirror mount 68-72 NOS
68-72 GTO splash shield seals NOS
76-81 stabilizer bushings NOS
76-81 stablizer bushings NOS
72 GTO gas pedal NOS
72 GTO dash name plate NOS
72 A body gas pedal bearing NOS
69-72 GTO automatic console shifter seal NOS
70-72 A-body stand pipe seal used
72 455 HO intake gasket set NOS
68-72 console hinge NOS
71-72 GTO front tag bracket NOS
68-72 GTO fuel pick up sock NOS
68-72 GTO left arm rest pad GTO NOS
72 left hand fender extracter NOS
72 right hand fender extracter NOS
stabilizer link pair NOS
72 GTO right hand tail light lens used
72 GTO left hand tail light lens
71 right side tail light lens used
71 left side tail light lens used
carter high performance fuel pump NOS
71-72 sport mirror gaskets NOS
68-up valve cover grommet NOS
carburator adaptor
cam retainer plate NOS
window crank springs NOS
GE high beam NOS
68-72 GTO dimmer switch NOS
69-72 lower steering column retainer NOS
lock nuts NOS
back up switch column mount
69-72 trunk release switch NOS
72-up seat belt warning buzzer
68-72 GTO door handle gasket kits NOS
68-72 GTO Spare tire hold down nuts NOS
center cap unkown
hose clamp NOS
72 tailpipe hanger NOS right
72 tailpipe hanger NOS left
tailpipe/muffler/exaust hanger
71-72 GTO bumper support NOS
69-72 steering arm left NOS
69-72 GTO steering arm right NOS
accessory floor mats firebird
AC vacuum switch NOS
bumper to frame mount right 71-72 GTO NOS
bumper to frame mount left 71-72 GTO NOS
upper bumper reinforcement 71-72 GTO NOS
right hood hinge GTO 68-72 NOS
energy absorbers NOS
68-72 GTO air conditioner case half NOS
kmart air filters
air cleaner wing nut
condenser NOS
wagoner flasher
starter drive
fan spacer
rubber pontiac valve cover gaskets
water pump gaskets 8 bolt set
water pump gaskets11 bolt set
felpro d-port metal exaust gaskets
TRW upper control arm bushing new
TRW rocker arms set of 16
crane inner valve springs set
67 GTO metal sign
pontiac accessory mirror
71-72 GTO ram air decal white pair
68-72 GTO trunk decal
71-71 455 HO fender decals white
455 HO air cleaner decal reproduction
72 455 HO trunk decal
Chilton's repair and tune up guide 68-73
Chilton's auto repair manual 1975
68 GTO glove box door
69-70 air cleaner elbow
Firebird 88-94 wheel lock nuts
spring ring battery cables reproduction
68 GTO turn signal assembly left hand
68 GTO turn signal assembly right hand
shifter boot hold down
71-72 GTO hood scoops
4 speed console bezel 68-72 GTO
miscellaneous bolts
68 GTO/Lemans clock
69-72 remote mirror driver's side GTO/Lemans
68 GTO steering wheel center caps
68 GTO ashtray assembly
lower dipstick tube with a bracket
67-68 Firebird steering wheel center cap - horn button
69-70 Ram Air pull cable
Hedman round port exhaust gaskets
Carter Zip Fuel Pump
Mallory chrome fuel pump new
92 Firebird decals NOS
Sun tach
70-72 GTO remote sport mirror
65-66 wood wheel collar
used ram air boots
ram air 4 HO block off plates
76-81 vacuum motor
68-70 GTO right hand hood scoop NOS
68-70 GTO left hand hood scoop
70-72 rear seat side trim panel, green
69-72 fan clutch NOS
71-72 gas cap NOS
68-70 carburator top NOS
72 8Track demo tape
67-68 vent window crank
71 455 fender emblem
68 rally clock
throttle cable bracket
68 GTO mirror NOS
76-81 heater control valve NOS
92 Formula decals NOS
73+ 455 grill emblem
PCV valve NOS
used lug nuts
intake vacuum switch NOS
68 two barrel choke coil
69-72 grand prix shifter release button
71 postcards
69 breakaway plates
radiator pet cock
Manley rocker arm set
69-70 Ram Air push rod NOS
64-66 GTO White 4 speed shift knob
accell spark plug wires
moroso spark plug wires
64-66 valve covers
69 GTO/GP carburator 7029268
front crank shaft seal
69-71 cast iron crossover
72 455 HO intake SR
71-72 heat chimney elbow
NOS 69-71 crossover heat shield
71-72 455 HO air cleaner lid
69-72 RallyII 14 x 6 used trim rings
"14"" used honeycomb trim rings"
455 2 bolt main caps
455 4 bolt main caps new A/M
Center support grill
window crank plate NOS, price ea.
Core support to frame bolts NOS per pair
Hazard knob screws NOS, price ea.
Striker seal pair
Heater valve NOS
71-72 automatic shifter knob NOS
Thermo switch NOS
Auto console gear selector NOS
Turn signal lever NOS
Panel to body brace NOS
72 GTO/T41 Right Fender NOS
72 GTO/T41 Left Fender NOS
72 455 HO Carburetor 7042270 SR
71 400 Manual Trans Carb 7041263
71 455 HO Auto Trans 7041270 2222 date
71 455 HO Auto Trans 7041270 rebuilt
"70 455 ""XF"" block"
70 455 64 Casting Heads
72 455 4-bolt Main Block
"71-72 15"" Rally Wheel KR"
71-72 GTO Upper Ram Air Pan
71-72 GTO Ram Air Air Cleaner NOS
69-70 D-port Ram Air Exhaust Manifolds
70-75 Firebird Tilt Column w/keys
68 wood steering wheel
TRW Camshaft TM 576
"NOS ""744"" cam"
"NOS ""041"" cam"
68 GTO Rally Guages and Dash Tach
68 GTO Rally Guages
65-66 Chrome Valve Covers
"R44S Spark Plug Set ""Acniter"" 3 sets"
"R46S Spark Plug Set ""Acniter"" 2 sets"
R45TS
72 GTO Grill Bezel Right-NOS
72 GTO Grill Bezel Right-Used
72 GTO Grill Bezel Left-Used Excellent Cond
71-72 GTO/T41 Front Bumper-Used
NOS Steering Knuckle Rt & Lt
71-72 Front Air Dam NOS
Black Bucket Seat Back
NOS Hood Retainer Pin Set
68-72 Sill Plates
NOS 72 GTO Tailpipes Rt & Lt
NOS 72 GTO Tailpipe Lt
NOS 72 GTO Tailpipe Hangers
68-72 GTO Lower Windshield Trim NOS
71-71 GTO Core Support to Bumper Filler Orig.
68 GTO Ram Air I Auto, Starlight Black/Teal-Survivor
68 Firebird Ram Air II 4spd, Aegena Blue/Black/Black
68 Firebird 400 Conv. Auto, Red/Parchment/Parchment
69 Firebird Ram Air IV, 4spd Matador Red/Black-Survivor
70 GTO Ram Air III 4spd Conv. burgundy(currently Black)/White/Black
71 GTO 455HO 4spd, Lucerne Blue/Black/Black
71 GTO 455HO Auto, Lucerne Blue/Sandalwood/Blue
Old 07-24-2017, 01:28 AM
63Banshee's Avatar
Interested in these items. What day are you getting to the track and what are your space numbers? Waiting till the swap to sell or are you doing pre-sales?
dj
Old 07-24-2017, 06:49 AM
1oldgoat's Avatar
dj
I will get there Thursday. My spaces are 364, 365, 334.
Old 07-24-2017, 07:14 AM
goatmanmitch's Avatar
goatmanmitch goatmanmitch is offline
Originally Posted by Ken MacNicol View Post
I will have a few of these at Norwalk for $4.00
Ken, the more I see this the more I want them. Will you be in the pits or do you have a vendor space? If not, maybe a phone number so I can reach you?
Mitch Kunath
Old 07-24-2017, 04:33 PM
Ken MacNicol's Avatar
Ken MacNicol Ken MacNicol is offline
I will be racing. Red and white Grand Prix
Old 07-24-2017, 08:17 PM
pontiac1981's Avatar
pontiac1981 pontiac1981 is offline
i'll be there, been going when it first started never missed a year.
Old 07-24-2017, 10:45 PM
Pontiac_Defender's Avatar
Pontiac_Defender Pontiac_Defender is offline
Originally Posted by 66gplvr View Post
My son and I will be there selling parts in the Swap Meet. Mostly 1966 Catalina, 1967 Catalina, some 1968 Catalina, 1969 Grand Prix, and 1972 Grand Prix. Swap spaces # 4 & 5. Stop by and say hi. My name is Jeff and my son's name is Doug. We hope everyone has a great time, as we always do!!
I'll have to come see what you have. I have a couple 67's.
This will be my first year attending. My wife and I are going to be staying at a hotel in Clyde.
Dave
1967 2+2 hardtop 428 w/auto
1967 2+2 convertible 428 w/4 speed
1967 2+2 convertible 428 w/auto
1967 Bonneville Brougham Coupe 428 w/auto
1967 Grand Prix convertible 428 w/auto
https://www.plainfieldpontiac.com/
*BE SURE TO LIKE MY FACEBOOK PAGE* https://www.facebook.com/PlainfieldPontiacRescue/
Old 07-25-2017, 10:14 PM
68pongto's Avatar
68pongto 68pongto is offline
Going for the first time this year, can't wait!
Old 07-29-2017, 12:29 PM
64CatalinaVentura's Avatar
64CatalinaVentura 64CatalinaVentura is offline
It won't be your last!
Frank (Catalina) Tupka
1964 Pontiac Catalina Ventura Sports Coupe
Connecticut Pontiac Association
Old 07-29-2017, 06:20 PM
red1975pacer red1975pacer is offline
I was planning on only doing sat and Sunday. Is anything going on Friday night that would make it a better option?
Old 07-29-2017, 07:59 PM
63Banshee's Avatar
Friday night is BBQ night.
Old 07-29-2017, 10:04 PM
Dave M's Avatar
Dave M Dave M is offline
I was hoping they would do that again this year
Old 07-30-2017, 12:59 PM
Is the BBQ Night open to anyone, at cost, or do you have to have a car in the show to attend?
Old 07-31-2017, 12:59 AM
This is my first time attending. Are there any events happening on either Friday or Saturday evening?
  #38
Old 07-31-2017, 07:30 AM
You guys certain the PY BBQ is still happening? I haven't seen anything posted about it. I thought that had run its course....
Mitch Kunath
  #39
Old 07-31-2017, 06:33 PM
63Banshee's Avatar
If it happened last year I missed it, so I don't know for sure. If the event doesn't put on the BBQ, we'll just have our own.
  #40
Old 07-31-2017, 07:37 PM
Sirrotica's Avatar
Wife and I will be there, we'll have the only ATV with a sprint car wing on. If you see a 2 seat ATV Go Kart that resembles a winged sprint car, that would be us. If I have enough time before we leave I'm going to try to add a nose wing on it. I might need that extra down force this year....... Gotta love winged sprint cars...........................
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
