Old 06-04-2017, 03:02 PM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
I love Atoll blue, have you considered leaving the top off by chance?
Keep it coming and nice find!
Old 06-04-2017, 08:04 PM
gto1369 gto1369 is offline
Removed front and rear suspension from the frame, then separated the frame from the body.
While cleaning up the frame I found the VIN, stamped twice, and frame info.
The frame restored to black.
ID:	456194   Click image for larger version
ID:	456195   Click image for larger version
ID:	456197   Click image for larger version
ID:	456198   Click image for larger version
Old 06-06-2017, 03:28 PM
mrrat1 mrrat1 is offline
Coming along.......whats your expected done date?
Old 06-06-2017, 07:42 PM
I too love the color and no, I'm old school and just love the look of the vinyl top on A and G bodies. Also, it is a all number matching SJ, so I want to keep it as built.
I'm further along than the pictures at this point so about 6 to 8 weeks ......... I hope
Old 06-06-2017, 08:20 PM
Pressure washed the underside, plenty of factory blue over spray with faded primer and some light surface rust.
Prepping the floor and firewall. Found the paint/roof trim code on firewall.
Underside finished in red epoxy primer.
Done, complete with blue over spray, undercoating and fresh black firewall.
ID:	456397   Click image for larger version
ID:	456398   Click image for larger version
ID:	456399   Click image for larger version
ID:	456400   Click image for larger version
Old 06-06-2017, 08:35 PM
very nice........!!
Old 06-08-2017, 10:30 PM
Everything installed on the frame and detailed
Getting the frame in position and reattached
Cleaned and rebuilt the rear end. That positrac fluid tag on the drain plug is the original one, both it and the drain plug were buried under about one inch of crud.
ID:	456505   Click image for larger version
ID:	456506   Click image for larger version
ID:	456507   Click image for larger version
ID:	456508   Click image for larger version
Old 06-09-2017, 09:13 AM
blue71ta's Avatar
blue71ta blue71ta is offline
Nice work
Old 06-10-2017, 11:26 AM
77 Canamman's Avatar
GM used also that limited slip red plastic tag on their trucks in that era. My '70 Blazer has the same thing on it's 12 bolt.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 06-14-2017, 02:36 PM
Progressing nicely..........well done!!
Old 06-14-2017, 09:28 PM
Front and rear suspension assembly
Rolling again
ID:	456818   Click image for larger version
ID:	456819   Click image for larger version
ID:	456820   Click image for larger version
ID:	456821   Click image for larger version
Old 06-14-2017, 09:33 PM
ID:	456823   Click image for larger version
Old 09-15-2017, 06:46 PM
blue71ta's Avatar
any updates you can share?
Old 09-17-2017, 07:48 PM
Well, hello again ! I've been busy with a new job, and a hurricane among other things, thankfully we got through it unscathed.
Time for the vinyl top
All done, time to get the motor and trans back together
ID:	463743   Click image for larger version
ID:	463744   Click image for larger version
ID:	463745   Click image for larger version
ID:	463746   Click image for larger version
Old 09-17-2017, 08:20 PM
Together and ready to go back home.
ID:	463757   Click image for larger version
ID:	463758   Click image for larger version
ID:	463759   Click image for larger version
ID:	463760   Click image for larger version
Old 09-18-2017, 10:58 PM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
Great thread and a nicely optioned SJ! Such a fantastic job you're doing, will be following this to completion.
Old 10-28-2017, 05:55 PM
Some more progress:
Motor and trans installed
Headliner in
Dash assembled and interior going together
ID:	466387   Click image for larger version
ID:	466388   Click image for larger version
ID:	466389   Click image for larger version
ID:	466390   Click image for larger version
  #38
Old 10-29-2017, 02:56 PM
428ho4spd's Avatar
Looks great! Forgot to mention earlier... nice to see the rear vinyl top seams below the glass done correctly!
  #39
Old 10-29-2017, 05:03 PM
Thank you, people look at me like I'm crazy when I tell them that's the way they were done when new.
  #40
Old 10-29-2017, 05:23 PM
ponchjoe's Avatar
Outstanding work Sir, love it!
