Old 08-10-2017, 01:58 PM
77 TRASHCAN's Avatar
Paul,
Does Hylift Johnson make hydraulic lifters for Pontiac's, now?
I thought our market was too small...are these Chevy units with the oil modification to the block???
Shut it off
Shut it off
Old 08-10-2017, 01:59 PM
61-63 61-63 is offline
Originally Posted by gtofreek View Post
150-155 on the seat, and 380-390 open.
Thank you
Old 08-10-2017, 02:03 PM
72LuxuryLeMansLa.'s Avatar
72LuxuryLeMansLa. 72LuxuryLeMansLa. is offline
I see there is only a 4° split in duration at .050".......What's the split on advertised?
Karl
Old 08-10-2017, 05:32 PM
sjdiesel's Avatar
sjdiesel sjdiesel is offline
I am happy to say this is the engine for my 1967 GTO!!!! Great work Paul!
My plan all along is to have a sleeper/cruiser. I want the car and engine to look stock and be totally driveable anywhere we want to go. I'm running a th400, 3.08 gears, ac and full interior.
Now I just have to get the car out of the paint shop so I can put it all back together!!
Sean
1967 GTO
Koerner built 468 with Edelbrock RP’s 315cfm by Butler, Luanti Voodoo HR 20510713, 4l80e, Holley Terminator EFI
The Following User Says Thank You to sjdiesel For This Useful Post:
Old 08-10-2017, 05:52 PM
Cool
Originally Posted by 77 TRASHCAN View Post
Paul,
meant to say roller lifters.............
Shut it off
Shut it off
Old 08-10-2017, 07:07 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Should be deep in the 11's.
Old 08-10-2017, 07:33 PM
vidguy's Avatar
vidguy vidguy is offline
Very nice!!!!
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
Old 08-10-2017, 07:50 PM
MUSLCAH MUSLCAH is offline
Where do I send a check....for all the hidden secrets.....I need a motor like that !
Old 08-10-2017, 09:07 PM
ponjohn's Avatar
Could this be duplicated with 6x heads?
The Following User Says Thank You to ponjohn For This Useful Post:
Old 08-10-2017, 11:14 PM
gtofreek's Avatar
gtofreek gtofreek is offline
290°/294°.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 08-10-2017, 11:17 PM
gtofreek's Avatar
Paul,
They make HR rollers for Pontiac, but they are Chevy bodies with Pontiac link bars. Actual, made for Chevy, lifters will not fit in a Pontiac because the lifter spread is different. Pontiac is wider. These lifters require the lifter bore feed hole be lowered 1/4". That can be done with a 1/4" ball burr in a die grinder, and a steady hand.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
Old 08-10-2017, 11:20 PM
gtofreek's Avatar
You can send that, made out to me, to:
468 My Back Pocket St.
Somewhere in the desert, AZ.
85777
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
Old 08-10-2017, 11:24 PM
gtofreek's Avatar
Well, I did build a 455 for a friend of mine with 6X-4 heads I ported, and a solid roller cam that ran 10.90 @ 122 or 123mph, in a 73 Firebird, on pump gas. That engine made less torque but made upwards of 550 HP. It was 9.9:1 compression. He's been racing it since 2008.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
Old 08-10-2017, 11:25 PM
gtofreek's Avatar
Originally Posted by vidguy View Post
Very nice!!!!
Nice, like yours huh?
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
Old 08-11-2017, 12:55 PM
shedgpeth4 shedgpeth4 is offline
those are money street engine numbers paul. the pics you posted on facebook of your 093 head rebuild show your skills as a machinist and builder!
Old 08-11-2017, 06:33 PM
gtofreek's Avatar
Thanks!
Looks like it will be next week before we get numbers for the manifolds. Dyno operator has the flu.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
Old 08-11-2017, 11:26 PM
gtofreek's Avatar
Here are the head flow numbers from Dave.
________In_____Ex
.100"___72.4___69.5
.200"___140____122.4
.300"___197.3__158.7
.400"___238.6__180.5
.500"___255.8__195.8
.600"___260.8__206.1
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #38
Old 08-12-2017, 05:59 AM
steve25 steve25 is offline
As always Dave does nice work!
  #39
Old 08-12-2017, 11:01 AM
ponjohn's Avatar
How big of a roller?
  #40
Old 08-12-2017, 11:02 AM
ponjohn's Avatar
Thanks!
Unacceptable...LOL.
