![]() Quote:
My wheel studs are 3 inchs long 1/2 inch threads,they come through the wheel studs approximately one inch,my open end lugnuts are 1 1/16 long on the outside of the wheel, they are also the shank style so they have another half inch threaded at least inside the wheel. The tech guy told me just to buy longer wheel studs...I'm like they are already 3 inches long!
![]() Quote:
Bleed your brakes, especially if you have any drum type.
Be safe! |
![]() Quote:
Usually on restorations I'm doing, and this actually applies to a few of my own cars here that I also like to race, I have most everything under the hood correct in detail, such as the correct colored throttle return spring. There are other minor things they sometimes complain about, but I'm just not willing to deviate on the restoration just to go make a few fun runs. And all that extra tension on the throttle just wears on the throttle shaft too, and I don't want to monkey around with springs coming off the front etc... When you think about it, carbs already have dual springs. There is the coiled spring on the shaft, and the spring on the throttle arm. Oddly they don't say anything about fuel injected throttle body setups on new cars, which only use a coiled spring on the shaft. It's just petty little things like that, that just drive me nuts with these tracks anymore. It's no wonder so many are closing down. Rising insurance rates sort of force this whole issue. I ran my firebird for 20+ years with it's single throttle spring and never had tech complain until recently. I understand the coolant overflow deal, and the battery should be secured, but they have gone nuts recently over wheels, wheel studs and lug nuts, seat belts and snell ratings and on and on. And if it's a stick car, oh my god that's another can of worms. It's to the point I don't even want to take a fast car to the track anymore. I'm happy in a 15 second ride, lol. Hopefully Surfsama doesn't catch too much grief and enjoys the day. Sunny there with highs in the mid 90's today so not too terrible. |
Good luck man it's hard work. Looks great keep us posted.
Sent from my XT1254 using Tapatalk
Giving To Others!!! V.P. Pioneer Valley GTO Association www.pvgto.com 67 Lemans 455 best et. 12.023@ 111 mph LVD 9/2008 68 GTO H.O. in progress? |
Sac raceway always seemed like a cut above runway racing to me. I've never raced there but I've been a couple of times for other events. Pretty low key place. I doubt they get too wound up about all the rules. Probably not going to get somebody measuring your hold down bolts to make sure they are 3/8" and fastened all the way through a frame member. Last time I went out I was in staging and the guy walks up and says you got a helmet? I say no. And he says if you break under 13s I'm sending you home. I just laughed and said I don't care, this is my last run and then I'm going home anyway. Then there was the tech that said I had to have a kill switch next time or I couldn't run. I said dude I'm not gonna drill my tail panel or my original bumper just for some hokie switch. I don't run drag tires so it's a 13 second car at best.
Robert 69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always ) http://youtu.be/eaWBd3M9MN4 |
Just got back and had a blast! I'm really happy with the car (driver needs some practice) but the car really pulled it out there with a best time of 11.77. My 60 footers are terrible but got into the 11s so I'm happy.
I did have one hiccup after a few runs I started smelling burning rubber on the return road so I checked the engine and found the alternator belt had twisted itself on the pulleys. Here's a couple of vids my wife and daughter shot (love them for the support): Tree'd a Mopar but caught me in the end: https://youtu.be/4EKxZpanvIQ Same race as above just a side angle: https://youtu.be/jktDYAFAFeM Payback: https://youtu.be/KwjWcMVnDQo
Only a pawn in game of life. |
Awesome....a lot of fun with the 4 speed.
Nice runs!
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
Great! Car looks sweet!
Good job congrats!
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
Impressive! I read where you didn't think you would be close to 11.49....I wondered how close you would get! If it was hot even more impressive!
![]() Quote:
![]() Car runs good |
![]() Quote:
I always make a point to hit this track when we drive up to Sac to visit family, I've driven our Camaro up there 10 hours, raced it while I spent the weekend up there, then drove it home, lol. |
Congrats on the runs. If you can get those 60ft times down , your looking at 40s . Its making power , and as mentioned better air will be a great benefit.
Thanks NO67GTO!
Thanks Ponjohn! Thanks Grivera! Thank you JSPont! Thanks OCMDGTO! Quote:
Close! It's and Autogear supercase M22W. Thanks Formulajones! Quote:
Good job!
#38
Awesome dude, congrats!!! Car looks and runs awesome!!
#39
![]() Quote:
I agree, always liked that track, more of a home town feel with relaxed atmosphere. Not many of those left. |
