Very true! But with the proper research a good choice can be made.
Ours does not fit exactly for combinations asked for here but the 526 we built for Johns's car made 928.9 hp at 7300 rpm with a BOP intake (920.4 w/ Victor), and this was 11-12 years ago. But to my point here for interest and regarding the comment about finding the right people. Our engine was done by a local engine builder here in town that on occasions does a few Pontiac's. A small but complete shop for all except crank work and align hone, he farms that out. And the High Port heads I bought as raw castings were ported by a fellow named Rick McConathy in Houston known for work on Chevy cylinder heads for Texas Pro Stock. He had never seen a set of HP heads before.
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
He may not have seen a Pontiac HP head before that, but over the years slick rick racing heads has turned out some great work. Stan
Pardon me, And Dragncar was asking me the same thing in a PM.
I assumed that my post would give a bit of credit to Richard along the way. Tom V.
And to add a bit of humor.... about 17 years ago the fellow that did a set of Edelbrock heads for me that supported 700 hp at 7000 rpm owned and ran a BMX bicycle shop. He had never seen a pair before.
I understand exactly what Calvin is saying but with bigger bore space and bigger cubic inches it's easier to throw parts together and make 1.5-1.8hp per CI..
As for the RPM's on a Pontiac I agree with Slowbird....I know for 100% FACT My family has turned our Pontiac bracket motors to 6900-7200rpm through the traps for over 19 yrs wo issues (with 4 diff cars)did it for so long I'd feel pretty confident to say going through at 7500 would still be a "safe rpm" where not to many oil system modifications would need to be done other than maybe a good oil pump. My current motor is only a 12.5:1 motor with .800 lift that doesn't have a very aggressive lobe......but is 615 cubic inches. It barely made 1000hp at 6100 But was dyno'd with C15 due to it's consistency.... Therefore I could still think like a traditional Pontiac guy ![]() Maybe I should get ahold of of the guy that said he could make some adapters so I could put some stock 1969 Pontiac valve covers on it..
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz “It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life” Notre Dame Head Coach Marcus Freeman 69 GTO NHRA Super Street Car 2860lbs 1/8 [email protected] 1/4 [email protected] in St.Louis April 2026 |
People switch to Chevy for the cost.
71 grand prix SJ 4280# 462 new for 2008 - 8.7:1 , 98cc 6Xs 246/209, 342 12bolt , BW S475 turbo JGS 50mm WG 56mm BOV. 600hp the easy way! |
Also because it's easier to get things done in the Chevy world.
And on a BBC with nitrous use it's not as easy to lift a head gasket
Much better head retention with the Chevy..
Call up Marcella and have him run a set of High Ports through his 462cfm CNC program, a little work on a BOP, Scott to cam it and you can have 1000 HP of pure PONTIAC back in your ride. Might be a little more cam than .800, but still very reliable. |
I was asking Brian if those slips were his. The middle one 1195 HP @ 8300 is impressive, they all are.
I dont mind hearing the particulars of Richards engine. The 79WS6 I would like to finish, I have been thinking about a 500HP "440" that looks stock. But a mild 800HP boosted engine does seem cool. |
IA2 block 4.35x4.35 bore and stroke, 10 to 1 compression, Wide port heads ported by Dave Bisschop, flow around 360CFM I think, 55mm cam with .904 lifters (morel) .265/.277 at .050 .706 lift with 1.5 Rockers. Super victor intake with Megasquirts MS3pro fuel injection. Procharger F1C with 10PSI boost. Car weighs 4000lbs RXT twin clutch connects the T56 Magnum to the engine...best to date is in my signature. I drive it with the belt off, get 16-17MPG. This year I put on about 15000Miles!
1965 GTO hard top, Black with a red interior built to drive and Race best so far 1.45 60’ 8.77@164mph . 6 Speed manual transmission. MS3pro Fuel injection Multiport , 517cubes 10 to 1, 3.50 gears, CNC E-heads wideport 350CFM by Dave B. 4025lbs with driver!!94mm turbo. Winner of the Hot Rod Dragweek stick shoot out 2017! |
I knew you drove it with the belt off (as did many Ford Racers ago who traveled to racing events) but was waiting for YOU to post that vs people complaining about the belt not being on all the time. You did good Richard and the 517 All Pontiac Block seems to be doing the job for you, as expected.
Tom V.
I wonder if its crazy, but is it possible to make some sort of "clutch" like a AC compressor uses for a centrifugal blower. Now THAT would be truly the best of both worlds. Have your cake and eat it too. Sort of like that old "Mad Max" scene where the guy hits the switch and the roots blower starts turning. We know it was BS in the movie, but could it work with a F1? |
Tom V.
#38
I've ran a Pontiac motor with close to .900 lift for a while... As for Mr. Magic man Marcella I attempted to go that route with him once upon a time 5yrs ago and for one reason or another it wasn't in the cards and that was when I had the money to spend. After meeting John at Norwalk this past year he's a stand up guy and I have always thought he does insane awesome work and the most impressive thing to me,about John is he is a racer himself and UNDERSTANDS his customers want to be out racing instead of waiting on this that or another...I don't take him as a procrastinator due to the amount work he cranks out,and the amount of folks using his products. Scott.....stand up guy without a doubt! A tremendous help to ANYONES program!!! But really I'm completely happy with what I have now and am enjoying working with the other parts of racing instead whatever Pontiac update I think I need year after year after year....the plan is to keep this thing in the old beast and just keep logging runs and downloading runs..... Also the plan is to continue to work with my 72yr old dad on making his car go faster and faster and help him reach his goal of racing longer than the Greek! That's where I have the most fun at the track is with the old man.
#39
Don't know how to post it, and really don't have time to troubleshoot how to do it right now, but my new engine made 1029 hp at 7000 rpm, peak torque was 803 at 6100. 541" with wideport Edelbrocks, Gustram cast intake
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
#40
Here is Dave Polichena's dyno pic:
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! W.E.C moment "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." – Socrates |
