Old 12-06-2017, 09:39 AM
Larry Navarro's Avatar
Originally Posted by Skip Fix View Post
"Neither did GM's crappy water based enamel being applied on Van Nuys builds, been there."
Yes my 78 started fading between the T tops and on one pillar and quarter panel at 2 years of age! Why in '88 I took it apart and painted it all in Glasurit black polyurethane(think Mercedes/Porches) and topped with clear.
Yeah Skip, my '79 was always cared for and garaged since new. I painted it in 2001 as the paint on fender tops were wearing thin from waxing/polishing over the years plus the pinstriping was going south. Even though it was garaged kept, it was a commuter. During the day, parked outside at Amoco Texas City refinery.
Old 12-07-2017, 12:52 AM
pippintook pippintook is offline
Rocky - that is interesting information that Pontiac might only started to clearcoat snowflake wheels staring in 1979 and that the colored areas were powercoated. It seems like most agree that any clearcoat applied to the snowflake wheel by the Factory was not very good.
Just wondering - what do you think of clearcoating snowflakes? Good/Bad? Is it possible for a clearcoat to last on car that is driven a lot ? Any info or experience on what might be a good clearcoat to use?
Old 12-07-2017, 09:42 AM
Don't worry it will last. Like I mentioned previously, my vintage dirt bikes get ridden hard. Lower fork legs and swingarms get hammered with dirt and the clear holds up. I spray the entire bike(s) down with WD-40, right before a race. It creates a non-stick barrier and mud falls right off.
Your car will never see that harsh an envirionment.
Old 12-07-2017, 10:31 AM
78w72 78w72 is offline
IMO, some dirt/mud on a vintage dirt bike that gets riden maybe on the weekends & coated with wd40 then washed off right away is a lot different than car rims that get exposed to the environment of a daily driven car.
car wheels are exposed to corrosive brake dust, high heat, rocks & debris during highway or street speeds. & worse of all curb rash & lug nut/wrench damage etc. all those things will wear or damage clear coat on wheels over time. also unless you find a clear made specifically for car wheels it probably wont hold up to all that abuse. even modern factory cleared wheels start to wear pretty quickly on cars that are driven regularly. the main issue though is the chips, once it chips you can't touch it up very well, you will always see it & chances are it will start to chip & corrode under & around the chip. & if you use a normal automotive clear as was suggested earlier it will definitely not hold up on wheels.
no clear & a little maintenance will look better & last longer IMO. i can post pics of my snowflakes that are just shy of 10 years old & have lots of miles on them.
Old 12-07-2017, 11:13 AM
78 TA KID's Avatar
78 TA KID 78 TA KID is offline
Not to change the subject but. I have a set of the early 78 15x8 snowflakes argent rims. I'm looking to restore. Does anyone know the correct formula and color for these rims. So I can get some paint mixed up. Thanks guys
Old 12-07-2017, 02:20 PM
the color is just called "argent." not sure on a paint code or formula but im sure someone will chime in with that info.
Old 12-07-2017, 05:24 PM
NO CLEAR will hold up to lug wrench/nut damage or curb rash, so that point is moot.
Your entitled to your opinion but I suggest you have experience with aftermarket product durability in both "environments" before making assumptions. Evidently you haven't since it's just an "opinion"...........
Old 12-07-2017, 06:46 PM
Larry - appreciate your feedback on POR-15 "Glisten" - that is one I will consider, if I clearcoat my snowflakes. Getting real life feedback on clearcoat products that work and hold up for snowflakes is tough. Many of the clearcoats look great when applied - but might not hold up that well.
78w72 - I like the idea of a high heat clearcoat made specifically for wheels and the tough conditions they face (ie. heat, chips, brake dust, etc). Do you have any specific high heat clearcoat product you can recommend ?
Old 12-07-2017, 07:30 PM
Talk about extreme heat and chemical durability, let me add this to further educate folks, as I completely forgot about the POR product sustains on an aluminum intake manifold.
The photo below of the engine in my '79......intake has been on two different engines. POR applied over 17 years ago. Looks as nice as the polished valve covers.
There's your proof. Extreme high heat/environment, caustic carb. cleaner at times, along with gasoline.
Don't entertain "opinion" nor "experiment" with products of questionable results. Do it right and do it once.
Old 12-07-2017, 08:50 PM
just wanted to point out that wheels are subject to quite a bit of abuse. when i mentioned "normal automotive clears" it was the SPI clear as was suggested earlier which is just for auto paint. ive never used POR clear, it sounds like good stuff. i dont really have any recommendations for clear as i didnt use it on my snowflakes. i have used spray clears on rally 2 rims & used a satin clear that was specifically for wheels. has held up great after 4 years but of course it will chip if you hit it with something...
Old 12-07-2017, 09:12 PM
i didn't suggest clear would hold up to lug wrench or curb rash etc, of course any clear will chip if you hit it with a wrench. was just mentioning that those things can & probably will happen, then its hard to touch up any clear. hence, the suggestion for no clear.
my opinion was of the example given of vintage dirt bikes & mud, yes its very harsh but a very different environment. car rims are not sprayed with wd40 to protect them from dirt & brake dust etc & then washed off after every use, so that point is also moot. i have experience with many paint & automotive products & their durablity as well as owning & dealing with these cars for a long time & generally only talk about or give my "opinion" of things i have experience with, no assumptions were made.
i never said POR clear was not good, sounds like it's great stuff. i mentioned the SPI clear that was suggested earlier & said normal automotive type clears wouldn't hold up. sorry if that was misunderstood...
Old 12-23-2017, 12:09 PM
burd's Avatar
burd burd is offline
The paint chips I have have the blue, red and gray paint codes, the SE code I've never seen, you see body color, that's wrong.
I have a nos Kelsey Hayes 7" flake, it has the correct gray on. Could have that matched, it isn't faded either.
Old 12-23-2017, 12:11 PM
burd's Avatar
I think there is a Tech bulletin on the flakes, I'll look. I remember seeing something. Maybe it was hours to charge to re-do them not sure.
Old 12-23-2017, 01:32 PM
burd's Avatar
Matt, I'll call you. There is a 6 page tech bulletin on paints, suppliers, paints used at which factory, all the various supplier paint formulas, interior, body, non metal paints, inc wheel and snowflake, too much to post.
Old 12-25-2017, 02:36 PM
POR-15 "Glisten" has positive feedback. Anyone have another specific clearcoat product they used (on alum wheels - ideally, WS6) and their experience - good or bad ?
Old 12-28-2017, 06:30 PM
burd's Avatar
I wouldn't clear them, use magic wadding every few years, they stay great.
