Old 02-01-2018, 03:02 AM
tailored68......... tailored68......... is offline
Default Polylock replacements
Originally Posted by skullbucket View Post
He can't use polylocks with stock bottle neck studs can he?
Yes he can ! Coz i had the exact same issue with them stock nuts. !
Old 02-01-2018, 10:30 AM
alanmay0 alanmay0 is offline
Installed the Mr Gasket 920 rocker arm locking nuts and all is fine. thanks
Old 02-02-2018, 02:07 PM
tiretread tiretread is offline
Originally Posted by 78w72 View Post
covers.
for now to verify there is no damage or other issues, i would just torque the stock nuts down to 20 & see how it runs/sounds. doesnt need to be at TDC because all the nuts end up in the same location once torqued.
Just for clarification, I have stock 093 heads and I'm going to put the rockers back on this weekend. I'm using the stock rockers, springs, and nuts. I can just torque down the crimp style nuts to 20 ft/lbs without worrying about TDC, is that correct? Thanks,
Old 02-02-2018, 02:24 PM
78w72 78w72 is offline
yes, correct. if the heads & block arent milled to change the factory dimensions the 20lb/ft rocker tightening just puts the lifter where it should be for preload.
Old 02-02-2018, 02:26 PM
^^^Thanks!
