Dan was just slow, he was working another machinist job for years because of the benefits. He had the block for a decade, yes a decade+. In fact he dies before he finished it. I paid for a torque plate bore and hone and deck. Just glad to get the engine back. i will have it finished locally. Hard part of it was done. Splayed billet caps were fit correctly.
I am having Scott Brown spec me a cam almost just like Jakes. Tad bigger as it will have 4.25 crank. 350cfm High Ports, pump gas deal. Very close to same engine but with 1/4" more stroke. |
Is this block filler the same as Sakrete cement patch filler? I'm trying to buy a hydraulic cement over here to fill blocks with but not having much luck.
Hello Brian,
Hope you and Jake have a great year running that beautiful bird. Best of luck. Jim
Jim www.raceV8s.com 1972 Trans Am drag car, 3300lbs, 468 ci, Iron D ports, 428 block, 9799103 crank, 9.48 @ 143mph, 6.0 @ 114mph in the 1/8th. |
![]() Quote:
Thanks bud!! Same to you and your son. Hope to see you guys at Norwalk again this year. Take care Brian
Boobs & bacon ![]() |
![]() Quote:
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
