Old 06-29-2018, 12:22 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Originally Posted by Jay S View Post
Sorry Paul, I see those specs for the 302h-2 you found don’t match the 308h-2 they offer right now. Only the .050 are the same everything else is different. I remember seeing that they had date codes stamped on the back end of the cam but I don’t recall how specific it is. Not even sure if they all have it. Sounds like measure time.
Jay
No problem Jay, we're all just trying to help the OP. A picture of the grind number would help make a positive identification. I'm not sure it matters much, regardless of the exact specs it's completely the wrong cam for his application.
Go fast, see Elvis!
Old 06-29-2018, 07:04 PM
Hillard's Avatar
Hillard Hillard is offline
Don't disagree with you at all Paul. I was only going to use it because it's what I had. However, I've since obtained a Comp 276AH-10. Should be a lot closer to working well with my combo than the Crane.
Old 06-29-2018, 07:13 PM
PAUL K's Avatar
I agree H. and understand. I'm glad you found something that was a better choice. That Comp should do well for you.
Go fast, see Elvis!
Old 06-29-2018, 10:25 PM
aceaceca's Avatar
aceaceca aceaceca is offline
Ran Crane H302 in 64 GTO back in the sixties. Still have the cam and the spec card here somewhere. Best time was around 13.1 or 13.2.
Old 07-01-2018, 02:28 PM
NeighborsComplaint's Avatar
Just went to the Crane Cams redesigned website. What a train wreck.
Old 07-05-2018, 09:46 PM
brut4s's Avatar
brut4s brut4s is offline
I have the Crane Cams H-308-2. If needed I can post a pic of the cam card. It is basically the Crane version of the H.O. racing specialties HC-03 cam
