Old 02-26-2019, 04:04 PM
North, what do you think of the font on the 0's on the above WY block?
with as many '69's as you have, would figure you would have as good a idea as any. thanks!
Old 02-26-2019, 04:43 PM
The zero's were more oval shape. That looks like the letter 'O' not zero '0'
The front of the blocks were blanchard ground, which has a very noticeable
'pattern'.
If it were ground smooth it would be quite noticeable as being modified.
If it was ground leaving marks, it would not look like the factory pattern.
The one pic looks very smooth.
Old 02-26-2019, 04:49 PM
The engine code seems ok but the numbers look suspect which makes you wonder. I'm out of town for a few weeks but when I get back I'll take pics of the numbers on all my untouched engines, see if there how consistent the font, depth and spacing etc is
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 02-26-2019, 05:46 PM
dataway's Avatar
dataway dataway is offline
Here is an extreme closeup of my EUN.
The difference I see on some is that the tooling used to produce this stamp appears to have a rounded profile on the actual working point of the imprint tool. Not a sharp point that leaves a very "V" shaped imprint, but more of a round bottom V.
Course I guess the tooling could get worn and perhaps round off by the end of a production run or something.
If you have any stamps at home, you'll notice most sets for hand stamping have a sharp profile ... again, could be because they are new.
Usually the letter codes seem to be slightly off in alignment compared to the EUN, I assume these were stamped after it was determined what configuration a particular engine would have.
If you look at the font used here ... in my opinion there is no way they would use an "O" shaped "0" ... They are still obviously different even on a modern computer.
Old 02-26-2019, 09:57 PM
grandam1979 grandam1979 is online now
This is a 1970 455,
Old 02-26-2019, 10:57 PM
What's the date code and block casting code on that 70 455?
(and VIN?)
Old 02-28-2019, 08:38 PM
E260 9799140 sorry I just sold the engine so I can’t give the vin.
Old 03-03-2019, 05:26 PM
This is a 1968 400 notice the first number is out of line low
Old 03-03-2019, 06:26 PM
I’ve often seen that, probably the machine that stamps the numbers is like a bicycle combination lock or an odometer. The wheel for that digit didn’t shift properly.
1969 Bonnie Cvt
Old 03-04-2019, 09:15 AM
dataway's Avatar
Yep, that wouldn't raise any flags to me, looks fine.
Old 03-04-2019, 11:28 AM
Look at this one the 7 and 8 are odd.
Old 03-04-2019, 12:11 PM
Not sure it's really 'odd'.
The factory used their own type of punches so if someone esle used the normally available ones everybody else could get, it would be clear it was different.
(basically their own font for them I think)
Old 03-04-2019, 12:27 PM
It’s the only time I have seen a 8 like that and the 7 with the down slash
Old 03-04-2019, 01:11 PM
dataway's Avatar
I've never seen that particular font before ... but I doubt GM got together and cooridinated all their EUN fonts.
And for the most part, I can't imagine anyone going to the trouble to forge an EUN, just no point in it ... unless as mentioned they thought it was supposed to match the VIN, but then most people that know that, also know where the VIN is supposed to be stamped.
Old 03-04-2019, 02:32 PM
That last picture is the vin from the front of the block same WT block from the previous picture.
Old 03-04-2019, 03:29 PM
dataway's Avatar
Jeez, didn't even notice that ... I haven't seen enough VINs to know what font they used, but that certainly looks factory to me. Can't imagine someone having stamps to match that font.
Old 03-04-2019, 04:39 PM
The WT block is original it sat in a barn for 35+ years till I got it.
  #38
Old 03-04-2019, 08:21 PM
Originally Posted by DANTIP View Post
This one is pretty bad.
Looks like many RaIVs I’ve seen
  #39
Old 03-04-2019, 08:23 PM
Originally Posted by grandam1979 View Post
This is a 1970 455,
I would say that came in a 71 car
  #40
Old 03-04-2019, 08:49 PM
Why would you say that?
(I have my suspects)
