Old 12-13-2022, 12:33 PM
mgarblik mgarblik is offline
Originally Posted by taff2 View Post
Yep, just bought one from him without the top, going to use a Holley LS efi manifold top on it to make an efi manifold for my sons big single turbo combo. Very reasonable at $325 without the top,I thought.
Be prepared to LOVE that manifold! I was very impressed. It's a little heavy and clunky but performs great. Plan on spending some time with Z-Spar splash zone or some other epoxy making the runners/ports line up. Your work will be rewarded. Good luck with it.
Old 12-13-2022, 01:57 PM
RBAILEY RBAILEY is offline
Originally Posted by R 70 Judge View Post
Any updates on this intake? I’ve been throwing around the idea of doing one of these without the extra plenum area added for a turbo build. Does anyone know the intake height to the flange where the adapter would bolt to? I could have cnc adapter plates made to mate the Holley piece to the Wenzler piece pretty easily if it would fit under my TA hood.
I could get you a measurement tonight.
The Following User Says Thank You to RBAILEY For This Useful Post:
Old 12-13-2022, 02:21 PM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
If your looking for just the height from the edge of the plenum at the head to the top edge with any top on is 5 1/2" , not a vertical length , just the distance from one to the other...
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 12-13-2022, 02:26 PM
Originally Posted by Bill Eveland View Post
Are there any issues with moving the outer bolts outward the 1/2" or is it pretty straight forward? My kre 380 gaskets came slotted already, ive never seen this before.
Not sure what question you are asking. I have a Gutsram on a set of 380cfm KRE High Ports. For me, because I don't plan on going wide-port ever, the solution for bolting a Gutsram to my engine was to mill into the outer runners at the root of the flange and up just far enough to clear inserting a bolt as the runner tapers and gets thinner the higher towards the plenum you go. The runners on a Gutsram in this area are literally 3/4 of an inch thick. One of the reasons it is such a heavy intake manifold.
ID:	603471   Click image for larger version
ID:	603473   Click image for larger version
Old 12-13-2022, 02:45 PM
R 70 Judge's Avatar
Thanks!! Sitting on a table how high would it be to the mounting flange for the 2x4 top?
Examples:
Northwind Carb pad 7 3/16” / 7 3/16”
Victor Carb pad 8 1/2” / 8 1/2”
James
1970 Trans Am
Old 12-13-2022, 05:32 PM
I want to love my Gutsram but I think it might be killing my bottom end. This is on a OEM block 474 w/Hi-Ports that flow 380@800, camshaft is solid roller w/760 lift [email protected], 108LSA. I am running 2 660 center squirters . So after 20+ runs on this new Gutsram equipped combo with ETs averaging probably around 10.25 @ 134.xx w/1.51 60ft, I decided to put a Victor with an 1150 on it to see if the 60 ft picked up. The 60 ft picked up right away with a 1.45 60ft and it even gained over 2 mph. Its possible the 2 mph gain was from better air than any day I had raced previously with the Gutsram combo. And like you said, the Gutsram had lots of work in it getting the ports matched up.
I still plan on using the Gutsram but I have some ideas to make it better suited for my combo. I want to take some volume out of the runners. I saw somewhere on this forum that somebody mentioned port reduction plates someone made for a Gutsram. I cant find that thread or post but would surely be intersted to see what others have done to take volume out of the Gutsram for smaller (474 vs 535) cube engines
Old 12-13-2022, 06:00 PM
We ran ours with with 2 1150 dominators and a 3/4" plenum spacer. But 541 inches and allot more cam. Tiger heads, 318/329 Ultyadyne cam. Just a touch over 1" lift. 1.016" if I remember right. 1.85 rocker arms. 110 LC. It was amazing how well it idled and how great the throttle response was with that intake. Much better than the flat/slight convex floor sheet metal intake we were running.
Old 12-13-2022, 06:23 PM
misterp266's Avatar
Sounds to me like you’re under carburetored for that motor. I ran an original Wenzler with two 750’s on a 406” and ran 10.10 @ 130 with a 1.33 60’ time. Cam was only 660 lift. Lots of port work on that one too!
" Darksiders Rule "
Old 12-13-2022, 07:05 PM
Yeah! That sounds like a perfect engine for the Gutsram! I imagine it was pretty punchy on that monster!
Old 12-13-2022, 07:14 PM
You could be correct as far as 2x4 tunnel ram carburetion goes in that 2 660s might not be enough.
What heads were you running with your Wenzler-1 tunnel ram?
I need to get my 60s to where yours are considering my mph is 136.86 (with the Victor/1150. ) (134.30 with Gutsram ...but air vastly different)
I would have loved to tried my original Wenzler on my hi-port headed combo but it seems a whole new roof added over the top of the runners would be the only way to use it on my hi-ports. I ran a original Wenzler on an iron d-port (48) engine and went 10.60 @ 126.25 1.48 60ft
Old 12-13-2022, 07:24 PM
misterp266's Avatar
Home ported 62’s. I think the original Wenzler was better for smaller motors like mine.
" Darksiders Rule "
Old 12-13-2022, 07:52 PM
Nice! That thing was/is? a screamer.
Old 12-13-2022, 08:31 PM
Originally Posted by Half-Inch Stud View Post
Would that be the number cast in the manifold..
I think he did that mostly on early models of his 1st design tunnel ram.
I own both types of Wenzler tunnel rams and neither of them have the phone number cast into them. But I have the seen the Wenzler like you are talking about with the phone number cast on it. Thought that was hmmm...different.
Old 12-14-2022, 03:15 AM
Examples:
Measured vertically from flange to plenum mounting surface it's 4 3/8"
Old 12-16-2022, 02:44 AM
R 70 Judge's Avatar
If it’s sitting on a table, how tall from the table to the mounting flange where the 2x4 adapter plate mounts to? Hope that makes sense
James
1970 Trans Am
Old 12-16-2022, 01:37 PM
R 70 Judge mines 6 9/16" for that height , not counting the 2 x 4 top. The wenzler 2 x 4 top adds another 2 1/4.
6.27@107
9.97@131
The Following User Says Thank You to Bill Eveland For This Useful Post:
Old 12-17-2022, 03:00 AM
R 70 Judge's Avatar
Thank you sir. I have an idea that may turn out really cool. I’m going to look into it. Now I need to get my hands on a Gutsram.
James
1970 Trans Am
  #38
Old 12-18-2022, 12:41 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Where did the name "Gutsram" come from?
