I will put a second layer of DEI Undercarpet Lite over top of the dynamat on the roof and floors.
Follow my rebuilds: IG: #67MoparBird https://www.youtube.com/@Nasty_Muscle_Cars https://www.tiktok.com/@nasty_muscle_cars 1967 Firebird 400 1969 Toyota FJ40 w/ SBC 350 Appeared on Gearz, Season 16, Episode 1, Segment 'What Are You Working On?' |
Ok, last question.......
I was thinking, if I use the Design Engineering 050113 Under Carpet Lite, it is not a self adhesive product. So I started looking at Noico Green 170 mil Waterproof Sound Insulation, Heat and Cool Liner which is a self adhesive product or Dynamat 11102 Dynaliner 32" x 54" x 1/4" Thick Self-Adhesive Sound Deadener. Do these two work the same? Looking to get the roof done before it leaves for the body shop hopefully next weekend. Thanks DM3
Those products do the same thing. With the under carpet lite there is an adhesive spray that you want to get if you go that route.
Not a huge fan of using a heavy product on the inner roof.....I've seen them decouple from heat and gravity.
I had a good result using a light insulation made of thin alloy foil sandwiching air filled bubble insulation.....its light, forms easily and I glued it on with spray adhesive.
Regards, Leigh Pontiacs I’ve owned…. 1960 Laurentian 283 1963 Laurentian 283 1976 Trans Am 400 1977 Trans Am 400 1951 Chieftain Flat head 6 1967 Firebird 400 convertible 1967 Firebird 400 coupe 1979 Trans Am 403 1971 Formula 455 (clone) 1969 Firebird 350 1968 Firebird 428 manual. Sydney, Australia |
