Prev Previous Post   Next Post Next
Old 07-17-2019, 07:53 AM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
Default IA2A aluminum wet deck builds
finally got around to dropping my stuff off at machine shop yesterday. Machinist had a bunch of questions. I had talked to Bob C and he said cometics with the small water holes are doing quite well. Talked to Jeff V and he prefers dry decking and titan copper.
Its going to be a bracket motor 850-900 hp, what is currently being run on aluminum block 4.350 bore and 14:1 compression range. I have a set of wet deck wide ports i plan on using for the first season or two, and i could dry deck them if i go that route, and then i will uncork it and either have them worked up or put some heads that flow on there.
thanks in advance.
