Old 01-09-2021, 11:08 PM
shoebox1.1 shoebox1.1 is offline
Pretty schnazzy with the weld wheels
ID:	557996   Click image for larger version
ID:	557997   Click image for larger version
GOD does business with people that mean business!
Old 01-10-2021, 11:19 AM
newmexguy newmexguy is offline
Originally Posted by 455Grandville View Post
I like that. Looked better than the 77 phoenixes.
Why was the name changed from Ventura to Phoenix? Any history on that?? A friend in elementary school dad was a Doctor. He had a new one back then. Not sure why, he could have drove a high end European car, and he did, his previous car was a BMW 2002. Guess he had other bills to pay back then and chose sensible transportation.
Old 01-10-2021, 11:21 AM
I’m not sure why they called it Phoenix
Old 01-12-2021, 11:35 AM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Because its a play off of the meaning of Fire-bird aka the Phoenix same reason the made a Grand Am after they had the Trans Am
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a
66 Star Chief Executive 59k mile 389
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2008 Saab 9-3 2.0T convertible
Old 06-11-2024, 10:50 AM
Gus ...when ya gonna drive that thing over and we put that 455 Pontiac in ? After the summer heat ?
Old 10-29-2024, 08:13 PM
blueghoast's Avatar
Isn't funny how these cars grow on ya but at first you couldn't stand them?
That car is SHARP.
GT
Old 10-16-2025, 01:23 AM
Been too long.. got a huge update. Pontiac Larry put my 455 in his 63 Catalina for testing and two outings it went 7.87-7.86-.786 85.,xx mph. Last weekend went 7.79 then 7.76 85.09 on not so sticky track. That’s at 3800 lbs. race weight. Hopefully the Ventura is lighter. Outta be swapped in by Xmas time allowing! Combo is mild .40 over 455, erson tq50 228/235/110. Stock 72 intake , 9.1-1 CR pump gas, 10 inch tci and 3.64 gear I believe. Not too shabby!
ID:	658752   Click image for larger version
ID:	658753   Click image for larger version
The Following User Says Thank You to shoebox1.1 For This Useful Post:
Old 04-02-2026, 02:36 PM
Here is the vid from last year when it went 7.7's with undecked re-ring 455 030 cast rod used TRW forged piston hyd small Erson cam near stock 6x-8 heads (minor bowl clean up) not gasket matched stone stock 1971 iron intake etc... Converter it TOO loose for this combo it was running 7.7-7.8 riding the downward backside of the torque peak that is lost in the flash of converter its will be better with a tighter stall in the Ventura regardless I would think 7.6 easy https://www.youtube.com/watch?v=s9kWO3l4vEc
Old 04-02-2026, 04:49 PM
Neat thing about the 75-79 X's is they are essentially the same underneath as a F body same vintage - so most TA handling stuff will fit nicely.
Old 07-02-2026, 10:31 AM
Been too long.. got a huge update. Pontiac Larry put my 455 in his 63 Catalina for testing and two outings it went 7.87-7.86-.786 85.,xx mph. Last weekend went 7.79 then 7.76 85.09 on not so sticky track. That’s at 3800 lbs. race weight. Hopefully the Ventura is lighter. 455 should be swapped in by Xmas time allowing! Combo is mild .40 over 455, Erson Hyd FT TQ50 228/235/110. Stock 72 intake , 9.1-1 CR pump gas, 10 inch TCI and 3.64 gear I believe. Not too shabby!
NEW 2026 update , the 455 isn't in the car yet and now Paul ( PJ Pontiac ) owns the car now . He made a deal with Gus (Shoebox1.1) and he drove it over this week. The swap should happen this Summer .. the three of us had also owned my 63 Catalina it bounced around 2x at the 3 of us before I committed and got it going. LOL So nothing new here.. When the engine was in my CAT the converter was too loose for the combo and I was running on a declining torque curve it flashed well past peak TQ rpm I am sure See video on this week ! the 260 finally did the posi burnout I required to see hahahaha https://youtube.com/shorts/yv7A-26fh...tegETSt5s990yj
