Old 09-17-2019, 11:10 AM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Default 1964 GTO Wood wheel option
Notice how the price of the wheel changed depending on what size car you bought (big car vs. GTO). The trim level of the full size car they deducted $15 off of what they charged you for the wheel.
$15 is nothing today but back then $15 was probably a good # of walking around money!
If I am reading this properly. Even at the price of, $39.27 on the GTO option cars, the wheel turned out to be an outstanding investment.
Almost like getting in on Microsoft stock early on.
Name:	63Lemans Wood Wheel.jpg
Peter Serio
Owner, Precision Pontiac
Old 09-18-2019, 11:44 AM
Dick Boneske's Avatar
Originally Posted by Chief of the 60's View Post
Is that a trick question?
No, not a trick question. I simply want to know what the original insert looked like. Was it burgundy or was it red on the perimeter? If burgundy is correct, I don't think '64 wood wheel owners have the correct piece available.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 09-18-2019, 11:55 AM
I would call it "tail lamp lens" red or the red that is on the '64 tail lamp bezel. Maybe a tad brighter.
Old 09-18-2019, 12:02 PM
That would be Marimba Red. Has anyone seen a repro that color or an original for sale?
Seems odd that this issue hasn’t come up for decades. When our two ‘64’s were judged, no deductions or comments were made about the wood wheel.
BONESTOCK GOATS
Old 09-18-2019, 12:10 PM
My comment was based on the shape of your chrome button. Based on your photos, it just does not seem to have the right shape and the plastic insert seems flush as opposed to recessed. That is why I asked if you had a better/closer picture.
Old 09-18-2019, 12:24 PM
You can label the color any way you want but I call it translucent red.
Old 09-18-2019, 06:22 PM
64-3Deuces's Avatar
64-3Deuces 64-3Deuces is offline
First insert is from my 64 GTO I purchased in 69; wheel was PHS documented. The color is the bright kind of translucent/reflective red. Second insert is one that I got with some other parts. Upon comparison it appears to be OEM though burgundy in color. Not sure if that is from sun exposure or is an early piece. My car was built third week of June. All the repop catalogs show the emblem with the bright red however Year One states that the color may differ slightly from the original. As I know my insert is original my guess would be that the bright translucent red would be the correct color.
As for the horn button the OEM has a solid back as opposed to a hole like the repops as the repops use a different casting process. On the OEM button the insert sits approximately 3/32” below the lip.
ID:	520481   Click image for larger version
ID:	520482   Click image for larger version
Old 11-18-2019, 12:50 AM
64woodwheel's Avatar
64woodwheel 64woodwheel is offline
Its hard to articulate the differences between the original horn button and emblem vs. the reproductions. But I assure you, they are distiguishable.
The chrome horn button is easy, they have a hole. No brainer.
The emblem gets a little tricky. There was a reproduction available in the late 80s early 90s that was spot on. The current reproduction on the market is good but not exact. The easiest way to spot it is the "T" in P O N T I A C is not the same height as the rest of the letters. It is too short. And, the outline of the V shaped crest is not the same shape/contour as the original. This is hard to articulate in words but pretty easy to see once you know what you are looking for.
Here is a picture of a repro horn button next to an original. Hard to see but the shape of the repro. is off just a little.
Old 11-18-2019, 05:10 PM
Tom Vaught's Avatar
Boost Engineer
Mine is exactly as described and obviously original as I bought the car new.
Tom V.
