| Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
Good day to be a Pontiac with that log manifold!!! You guys have no idea what I have to deal with to get my headers done. I had to make a header and he made a jig out of the one I made and made the bend better as he has access on some tight bend tubing..
Yes it is. I was just going to make my own when I saw these available. They will save tons of time and headaches.
1964 GTO 501, Edelbrock Heads NA, 3460 lbs. 9.76 @ 137mph 1971 Trans Am Lucy Blue, 11.56 @ 115 1966 LeMans. 6.0L LS single turbo, 8.85 @155 mph 1976 Trans Am twin turbo 462, SD Edelbrock heads 8.03@171 mph 2009 G8 GT |
I have been looking at these as well. I wonder if I could make them work with a March Serpentine system.
1980 Trans Am - Street/Strip 462 Best: 7.08@95 with 1.49 60' in the 1/8th. [email protected] in the 1/4. N/A, 3700 lbs, 3.42's, Pump Gas. Admin of Pure Pontiac Powered Outlaws on Facebook. |
I reached out to Stainless Header Mfg the other day and here is the response I received.
"The grass is not greener on the other side, its just fertilized with different $h!t" |
Good info, I hope he does d ports too.
This will probably make this thread width large but you can see the welding that the gentleman does.
Click on picture to make larger or copy to another location and expand the photo. Tom V.
Nice work fair play.
I'd be in for a D port log manifold, from here I could get my local to finish the rest with the DP. $800 with v band outlets would be ideal.
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct @ 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline |
Web site says they make d ports too.
Guys, Steve from Stainless Headers gave me a breakdown on pricing for a possible Group Purchase.
This is just an estimate, but should be close in terms of pricing: Here is an optional Group Purchase breakdown... Qty 1: $799.90 Qty 3: $784.90 Qty 5: $764.90 Qty 10: $734.95 So I will start the list below. If you would like to add your name... simply copy and past the most current list into a new post and then add your name. I will start: 1) AIR RAM (Nick) (Round Port) 2) 3) 4) 5) 6) 7) 8) 9) 10) SPEED SAFE, NICK
**Not compatible with standard Pontiac "D-Port" heads. Meant to fit stock Ram Air IV heads and all aftermarket variations, i.e. Edelbrock Performer and KRE High Port cylinder heads**
Agree, you need to make sure that the "D-Port" applies to Factory Pontiac Cast Iron "D-Port" heads.
I am reading that it applies to aftermarket "D-Port" aluminum heads or to Factory 455 HO and RA-IV Round Port heads as well as Aftermarket Round Port heads. (No RA-V heads or stock cast iron street type Pontiac Heads). Tom V.
2) mysticmissle (JEFF) (roundports) 3) 4) 5) 6) 7) 8) 9) 10)
1968 firebird cameo white on red 400 4 speed 1969 carousel red firebird 455, richmond 5 speed 1964 gto pump gas, 505 IA2 EHeads, EFI, 92 mm turbo ice cream getter in process now.... 1970 lemans hardtop, gto clone Atoll Blue 1972 Maverick powered by 2004 gto ls1 and t56 6 speed, 8.8, fox strut front end, wifes car |
1) Erik B - (Will be refunded difference) 2) AIR RAM (Nick) (Round Port) 3) Mysticmissle (JEFF) (roundports) (First Price point) Qty 3: $784.90 4) 5) (Second Price Point) Qty 5: $764.90 6) 7) 8) 9) 10) (Third Price Point) Qty 10: $734.95 SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t" Last edited by AIR RAM; 10-08-2019 at 05:01 PM. |
SPEED SAFE, NICK Quote:
Tom V, you're the "turbo master"... what are your thoughts? Quote:
Similar to how I did my manifolds for d ports. They work fine...
#38
This is GREAT stuff! I think there should be posts to link in to the Street, Race, and Exhaust sections to get more exposure...
I SO want to do this, but I'm upside down, cash wise, right now :-/ The D-port (REAL D-ports, not the Round port as a D) design sounds very promising. I'm guessing A, F, X, and B bodies could use the same manifold.
John IG: @crawdaddycustoms YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos |
#39
Cast Iron Log Ford GT manifolds have powered 5.4L engines to 200 plus MPH on the street and at the Bonneville Salt Flats. The Custom Built Pontiac Manifolds should be just fine. Tom V.
#40
SPEED SAFE, NICK
