Old 10-23-2019, 12:05 PM
dataway's Avatar
dataway dataway is offline
Originally Posted by Cardo View Post
You're probably going to need to put a yoke in the trans too to keep it from leaking out the back if you want to run it.
Yep ... gotta go dig the driveshaft out of the parts pile. I do have one of the plastic plugs in the back the seals against the seal and covers the output shaft.
Old 10-23-2019, 02:12 PM
dataway's Avatar
Did a more thorough measurement of flex plate to TC.
It's a smidgen under 1/4", I can just wedge in my home made 1/4" feeler, but it's flexing the plate a bit to do it. So call it 7/32", should I be ok there?
Found a bit of fluid on the lower side of the TC .... didn't think I spilled any on it when I added 1 qt before installing. I assume they pressure test these before shipping them. The 1 qt I added should all settle to the bottom of the TC without even coming up to the level of the input opening correct?
