Old 11-23-2019, 10:09 AM
Formulajones's Avatar
Dad has run these on the back of his GTO since about 1970. Not sure they are made anymore but they are stainless and work nicely with the rest of the stainless on the car. They've been on there so long and I'm so used to them that when they were removed for the restoration it looked like it was missing something, lol.
You'll have to look closely, they are hardly noticeable. As small as they are, they do keep debris from hitting the lower quarter, and the factory stainless along the bottom of the quarter also helps.
In the past I've also used temporary rubber flaps to get through situations you describe and I clipped them on the quarter lip with the ACCO metal binder clips.. Then simply remove them when not needed.
ID:	525198   Click image for larger version
Old 11-24-2019, 12:41 PM
i82much's Avatar
i82much i82much is offline
Some good ideas in this thread, thanks to everyone that posted. I took it for a ride last night, temp was in the mid-30's and clear. Ran great. There's nothing like an old carbureted hot rod on a cool night, I love the way the cool air makes then run so nice.
Old 11-24-2019, 04:26 PM
carbking's Avatar
carbking carbking is offline
Don't know about the mud flaps, will leave those to others.
As far as the tires are concerned:
In a different lifetime (well about 55 years ago) snow tires were expensive, and SOFT. A set would barely last through one winter. Dad found me a spare set of rims, and mounted some used regular tires, but still with good tread, and a set of chains. Carried these in the trunk, and the weight helped the front/rear distribution for steering control; and if the weather got bad, simply changed out the wheel/tire combination. Once the weather improved, changed them back. Don't know how much wheel well clearance you might have; metal chains might not work. There used to be at least one company that made a set of fabric "chains" that require less clearance.
Jon.
Old 11-24-2019, 05:11 PM
Old Goat Racer's Avatar
I put mine in the snow once.
Everybody knows somthin.
Nobody knows everything !
Old 11-25-2019, 09:39 AM
HO Kenny's Avatar
HO Kenny HO Kenny is offline
Originally Posted by Boogy View Post
Besides the sand bags, don't forget to pack an old coffee can with a foil blanket, 2 Hershey bars, and a candle. Also, a set of extra long jumper cables, a tow strap, and clevis or two.
If you decide to put a hitch on that thing to tow your pre-80's snowmobile, don't forget an a spare drive belt, spark plugs, and an extra windshield/duck tape to replace/repair the one that breaks when you roll it the first time. It gets damn cold without the windshield!
Thanks, I needed that. Lol
Don’t even think of putting all seasons on at about 20*F they turn rock hard. With that much torque and that nice a car traction is life. It’s usually the ice that will get you in trouble.
Toyo observe were the best winter tires we’ve used. They have micro bits in them. No need for studs. Very smooth on dry pavement as well.
Old 11-25-2019, 04:24 PM
In the late 1960's early 1970's I drove my 1965 GTO year round. It was actually a good winter car with it's limited slip, 4 speed and low (3.90) rear gears. It was also jacked up several inches. I commuted 40 miles each way to work, from NH to Mass 5 days a week. I never got stuck in the worse snow storms or even on icy roads. Car had 28 inch tall by 5.5 inch wide snow tires. Enjoy driving your car. It won't rust out while you own it.
Old 12-02-2019, 09:00 PM
Tim Corcoran's Avatar
You got a 65 GTO and your driving it on the snow and salt. I would call that blasphemy.
Tim Corcoran
The Following User Says Thank You to Tim Corcoran For This Useful Post:
Old 12-02-2019, 09:49 PM
At the time the car was worth a couple hundred dollars. Everyone drove their cars year round.
Old 12-03-2019, 12:55 AM
i82much's Avatar
assuming this is directed to me, i will not drive when there is a recent snowfall or a lot of ice on the road, but there are many, many days from oct-april here where the roads are mostly clear but you can still run into black ice.
so basically i am thinking just to be extra safe i might run snow tires on cold days when the roads are clear, just in case there is some ice i can’t see.
i think the county uses magnesium chloride but i can’t see how that would be an issue on a dry day?
Old 12-03-2019, 04:21 PM
jonmachota78's Avatar
jonmachota78 jonmachota78 is offline
magnesium chloride is extremely corrosive to vehicles. I would not do it
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports,
3" pypes, Hooker 1 3/4" headers, hydraulic roller,
10" Continental, 3.42 gears
11.5 @117.5mph 3900lbs
([_|_] ##\|/##[_|_])
Old 12-03-2019, 04:37 PM
leeklm's Avatar
leeklm leeklm is offline
"i think the county uses magnesium chloride but i can’t see how that would be an issue on a dry day?"
If if gets caked on the roads like it does around here, the underside of car, wheel wells, etc will get coated in the dust. Run through a puddle or some rain, and instant salt bath in all the nooks and crannies where the corrosion begins. Of course it will not rust overnight, but if you want to keep it nice for the next owner or two... I am probably being a little anal, but back in the day these cars would rust out in just a few years! My 71 demon was already a rust bucket daily driver when I purchased in 82!
I know a lot of people that will not take their classics out of winter storage until we have had a good rain or two to wash the road salt into the rivers and lakes, which of course is a another discussion....
With all that said, your area uses far less salt and chemical compared to here in the rust belt, so likely much less of a concern in your scenario.
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight
Old 12-03-2019, 06:26 PM
i82much's Avatar
Alright, thanks everyone. I have seen the light. I have a 72 K10 truck that isn't insured, I use it for plowing the driveway. It's a lot rougher than the GTO. I will put it on the road and drive it every now and again to get my classic car jollies in the winter, and keep the GTO in the shop.
Still gonna need some mudflaps though
Old 12-03-2019, 10:14 PM
Street driven 72s have been disinagrated here by the salt. Rust repair is the worst. Drive the disposable in the winter. Here anyway
Old 12-04-2019, 08:17 PM
I've had my present GTO for 30 years now. I've always driven it on nice winter days when the roads are dry. It has no more rust or corrosion than it had when I bought it in 1989. If you store your car in an unheated garage salt will not effect it. Salt by itself will not hurt your car. Just look at trucks used in salt mines.
Old 02-07-2024, 12:46 PM
i82much's Avatar
This thread seems to have really caused some consternation, so I'm bumping it. I'm not going to drive my car in winter. The rust issue just means it's not worth it.
I gotta say, it sucks. I grew up driving my car every day and I want to put as many miles on it before I die as possible. I don't care if I get dings or scratches in the paint or the engine compartment gets ugly, I think these cars were made to be driven. But the reality is that rust is just such a killer and I have already spent an ungodly amount of money repairing rust damage from east coast winters once and I don't want to have to do that again.
When I posted the thread I was dead serious, I was hoping that the magnesium chloride wasn't so bad as long as you drove in dry weather. But after hearing from everyone, I am convinced that would be foolish. I get that it maybe sound silly to some of you, but I have really good memories of going out to my hot rod every single day, even in the snow, and driving to work. I have accepted, however, that those days are over at least until someone develops a non-corrosive deicing solution for the roads.
Old 02-07-2024, 01:20 PM
They already have...beet juice
I too am obsessed with rust - i can hear my daily rusting in the garage rn.
Sometimes I wish I had a saturn or a corvette lol.
Old 02-07-2024, 01:25 PM
ta man ta man is offline
Rich Guido...Alberta to Florida...run mid 8's drive back...he would know about snow tires or traction on a GTO
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer
  #38
Old 02-07-2024, 01:53 PM
i82much's Avatar
To me, that's the perfect car ... something that looks good, is fast, but you'll drive it anywhere and do so frequently.
  #39
Old 02-07-2024, 05:31 PM
Stuart's Avatar
Stuart Stuart is offline
You'll have to check to see if they have your size, but Hakkapelitta tires from Nokian are probably the best snow tires available. Don't forget to put snow tires on all four wheels, not just the rear like we used to do. https://www.nokiantires.com
The Following User Says Thank You to Stuart For This Useful Post:
  #40
Old 02-07-2024, 08:41 PM
Really the fast stick car and Pontiac powered real street car out there..Rich is kickass
