Old 12-06-2019, 05:13 PM
Dragncar Dragncar is offline
Those are spectacular numbers !. Under .500 lift with a AFB and AFB intake too boot. I have a low rise AFB intake and a high rise AFB intake laying around and I figured they were worthless for making power. Not true.
Old 12-06-2019, 05:25 PM
ta man ta man is offline
Awesome! Did Dave build the whole engine or just the head work?
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer
Old 12-06-2019, 06:14 PM
geeteeohguy's Avatar
Impressive!
imho, your 389 build is quite the value adder for any factory built '64-66 389 4bbl car.
I feel exactly the same. Excellent numbers for a good ol' 389. Helped a friend put together a '65 389 with those same pistons and heads but the heads were not worked and the cam was a Comp 268. 4 speed '65 with a 3.36 gear and the car really scoots......most don't believe it's 'only' a 389! I'm running a warmed over 389 in my own '65, and it runs way stronger than the 428 it replaced over 30 years ago!
Jeff
Old 12-06-2019, 06:41 PM
Cardo's Avatar
Cardo Cardo is offline
Dave did the head work and helped with a lot of advice, and Paul Carter also gave a lot of advice and picked the cam for me. A local machine shop (owned by a friend of the family) did all of the machine work and most of the final assembly.
"I know just enough to keep me here, but not enough to get me out"
Old 12-06-2019, 09:47 PM
Who? Worrell’s or Gerald Dixon are the last two ship in the Louisville area I would trust with a Pontiac.
Dr. Thomas Sowell
Old 12-06-2019, 10:26 PM
Cardo's Avatar
One of Dixon's protegee's. He's asked me not to mention his name in this forum at this time because he's entirely covered up right now. It took a year to get my engine back, and was well worth the wait, but it's a one man operation and he is buried.
The Following User Says Thank You to Cardo For This Useful Post:
Old 12-06-2019, 10:45 PM
ponjohn's Avatar
ponjohn ponjohn is offline
1hp per ci - nice.
Probably some more in it with 4 tube headers.
Old 12-06-2019, 10:54 PM
Cardo's Avatar
I think so too. I'll be putting a set of the Ram Air manifolds on it with 2.5 inch mandrel bent exhaust. The dyno operator did say that his dyno is a bit stingy too, so i was glad to hear that.
Old 12-06-2019, 10:58 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Good job!
Go fast, see Elvis!
Old 12-07-2019, 12:06 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
... 262/268 duration @.050...
Old 12-07-2019, 12:11 AM
Truly impressive results running the AFB carb//intake on top.
Big Congrats
Old 12-07-2019, 12:22 AM
Tom Vaught's Avatar
Boost Engineer
Lunati Voodoo 702 HFT cam 262/268 duration @.050 and .468 / .489 lift degreed and installed at 106 deg
I ran a similar cam with a 240 cfm #16 D-Port head (400 cid) about 20 years ago. .540 / .565 lift. 255/265 @ .050 106 also.
Great higher end power, drove ok on the street with the Jim Wangers 4.33 geared 4 pinion 10 bolt rear (before I sent the 4.33 rear to Tenny to go back under the Wangers 64 GTO.
Gas mileage sucked on a 150 mile trip. 20+ gallons used on that trip.
So my point is you can make around 500 HP with a similar engine and factory d-port heads but the engine will be a gas hog based on my experience. But it is not a true street engine by any means with that duration camshaft.
I did drive it on the street about 4 years.
Best it ever ran was 11.55 at 117 in the 64 GTO convertible body.
I still have the complete engine on a stand in the garage.
Nice job on the dyno numbers.
Tom V.
Old 12-07-2019, 02:34 AM
I grew up with a 66 Catalina station wagon. 3 on the tree. Got 19mpg on trips. About what SUVs get today.
Old 12-07-2019, 07:11 AM
Cardo's Avatar
Here is the cam info from Lunati. I accidentally posted the advertised duration. Duration at .050 is 219/227. Not a big cam at all, should be fine for gas mileage.
"Hydraulic Flat Tappet Cam. Great torque monster for 400-455 c.i. daily driven street performance vehicle. Excellent torque and HP production with heavier emphasis on the low to mid range. Will work in tri-power applications with 389-455 c.i. engines. Choppy idle. ;Advertised Duration (Int/Exh): 262/268 ;Duration @ .050 (Int/Exh): 219/227 ;Gross Valve Lift (Int/Exh): .468/.489 ;LSA/ICL: 112/108 ;Valve Lash (Int/Exh): Hyd/Hyd ;RPM Range: 1300-5500" Just to give credit where credit is due also, I rebuilt that Carter with a kit from Carbking. Top notch kit. I should probably order a spare.
Old 12-07-2019, 08:46 AM
redhawk44's Avatar
redhawk44 redhawk44 is offline
Nice build, you'll definitely feel that torque when you get on it.
Let's make welfare as hard to get as Veterans benefits!
Old 12-07-2019, 09:40 AM
Cliff R's Avatar
Cliff R Cliff R is offline
+2 or 3
1HP/CID with a pretty much "stock" type build is getting it done nicely in my book.
It will be pump gas friendly and reliable in long term service as well. Plus nice to see some "old school" parts clearly showing the potential of the early stuff which we don't see much of on here........Cliff
Old 12-07-2019, 11:55 AM
455rebel 455rebel is offline
Kinda brings some respect to the little, engine. Around hear people still crush them, might pick one up for a future build?
1970 amc rebel 4-door, faded blue paint,290 emblems on car, 455 under the hood.Turbo 400,3.15 gear.
Best so far 1/8 et,8.90 on street tires,
Since that I have added 400 heads.
I call it a rat sleeper.
  #38
Old 12-07-2019, 12:20 PM
pastry_chef's Avatar
1965 389 with 76 heads built and ported by SD Performance
Congratulations, what size valves?
  #39
Old 12-07-2019, 12:26 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Definitely nice looking and a nice build. It will be interesting to see how it runs in the car. Carbking's kits are really nice.
Skip Fix
  #40
Old 12-07-2019, 01:07 PM
Cardo's Avatar
Thanks again everyone. I just did A LOT of reading mostly on here, paying attention to what's been posted here in the past, especially guys like Paul Carter, Paul K, Cliff and SD Dave to name a few. Talking to SD Dave Bisschop and Paul Carter to comfirm what i was thinking, and again Paul making the cam choice for me. I was between a Crower 60916, and the one i used that Paul steered me towards. Thanks again Paul. I love the old Carter AFB's. Simple, reliable and will get the job done. Stock size 1.96 / 1.66 valves.
