Old 12-27-2019, 09:52 AM
RocktimusPryme's Avatar
RocktimusPryme RocktimusPryme is online now
I have a couple classics, I drove them more this year than any other and in the coming year even more. I used to be worried about breaking down, but hey worse comes to worse whats a tow bill? I think my classic insurance even covers it anyway.
I really need to get the blower motor into the Firebird so its easier to drive it in the morning when windshield fog is a concern. I just don't want to pull the damned fender off.
Old 12-27-2019, 10:20 AM
steve25 steve25 is offline
One things for sure that being if your motor runs valve springs that have over 160 psi on the seat then for the valve springs to have there intended life expectancy you need to back off on the valve adjustments if the motor will sit unfired for more then 2 months.
This harm is more pronounced when springs are set up to work within .100" lift of there coil bind height.
Even just cranking the motor over 1/2 a revolution will help a lot every 2 weeks!
Old 12-27-2019, 10:28 AM
455rebel 455rebel is offline
2 to 3K,a year. I'm semi retired and it's my errand car. Pulse local Sat night car show, part time during summer. Drive most every day , March through Sept. It's kinda a rat car, so using with grease shop cloths, or on farm with mud on feet, is the norm.
1970 amc rebel 4-door, faded blue paint,290 emblems on car, 455 under the hood.Turbo 400,3.15 gear.
Best so far 1/8 et,8.90 on street tires,
Since that I have added 400 heads.
I call it a rat sleeper.
Old 12-27-2019, 10:37 AM
Formulajones's Avatar
Every day.
Old 12-27-2019, 11:41 AM
72projectbird's Avatar
Originally Posted by mchell View Post
Im taking it to Home Depot, the restaurant or the beach every chance I get.... life’s getting short!
I do the same. I've made countless runs to HD, the beach, going out to eat, or whatever else.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 12-27-2019, 12:06 PM
prostreet64's Avatar
prostreet64 prostreet64 is offline
Curtis and I try to get our cars out once a week, year round, weather permitting. Mileage probably totals about 500 a year plus those 1/4 mile at a time events! We have driven to car shows not too far away; 3.73 gears not being very conducive to highway speeds.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car.
79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.60 @ 126 so far...
Old 12-27-2019, 12:40 PM
Gator67's Avatar
Gator67 Gator67 is offline
Not nearly as much as I would if I didn't live on this crappy, poorly maintained dirt road. Get tired of cleaning the car every time I get to the end of the road, then cleaning it again when I pull back into my driveway. It' bad enough that I find the perfect day for me to drive is two days after a torrential downpour. No dust and the mud puddles are dry enough to not sling mud over my rockers and quarters. :/
I was in the same boat as you. 3/4 mile of dusty gravel road dampened my enthusiasm to take my cars out, much more so than I anticipated before we built our house. After two years the city paved the first 1/2 mile, and to appease neighbors who were totally against paving, they used a polymer emulsion on the rest--tilled it into the soil, graded and compacted it, and then applied a couple top coats. Dust control is a big priority here, so we lucked out. I take the cars out much more now.
Old 12-27-2019, 02:11 PM
torqhead's Avatar
torqhead torqhead is offline
Varies year to year, 4-6K which is primarily in the summer. I do get it out in the winter but it's dependent on weather. Usually avoid if there's a bunch of sand on the roads after we get snow.
Old 12-27-2019, 02:53 PM
craigs69's Avatar
craigs69 craigs69 is offline
Not often enough to justify the investment, insurance costs and floor space that it takes up. I'm likely getting out of the hobby this coming spring.
69 Judge convertible........clone! Carousel red, parchment, hideaways, TH400, 10" Continental 3200 stall, 12 bolt with 3.42, 469 c.i. with ported #48's, ported cast iron intake, Cliff's Q-Jet and ported 2-1/2" Ram Air manifolds.
Old 12-27-2019, 05:32 PM
stevep's Avatar
stevep stevep is offline
I have a few Pontiacs and I drive all over the place them as long as there no salt on the road and it is over 40 degrees.
I drove my 64 Bonneville Safari 7000 miles from May to October
Old 12-27-2019, 06:35 PM
72LuxuryLeMansLa.'s Avatar
72LuxuryLeMansLa. 72LuxuryLeMansLa. is offline
100,000 miles over the last ten years. It's down for an engine change now.
Karl
Old 12-27-2019, 07:55 PM
goatless's Avatar
goatless goatless is offline
Didn't drive them near enough this year due to working a lot. Still sounds like I drove them more than quite a few here, though. I use them to run errands or go out to dinner or just up to the lake. If I didn't need a truck for work, I'd drive them to work too. The roads are pretty crappy with salt now, but if we get enough rain to clean them off, I'll still drive through the winter... until they salt again.
1966 GTO
Old 12-27-2019, 08:00 PM
glhs#116's Avatar
glhs#116 glhs#116 is offline
Daily. Around 50 miles a day.
Sam
Sam Agnew
Where you come from is gone; where you thought you were going to, weren't never there; and where you are ain't no good unless you can get away from it.
Ministry - Jesus Built My Hotrod
Old 12-27-2019, 08:09 PM
i82much's Avatar
i82much i82much is online now
I don't know anything about your situation, but I've found that the costs steadily decrease over time. The initial cost of a restoration - body & paint, drivetrain, interior, it's unreal. But once you've got a complete, running car with a decent paint job, you only need to spend a few bucks every now and again to fix little things as they come up or as you want to upgrade.
If you've already bitten the bullet on the big $, maybe stick it out and see if you can spend some more time in the car? I finally started driving mine last summer after all kinds of issues with the initial restoration and several engine repairs. But as far as I can tell, everything is good and starting to come together. Doing things like fixing leaks and gauges right now, so nice to see a clean garage floor for once!
Old 12-27-2019, 08:25 PM
ignaro's Avatar
ignaro ignaro is offline
Daily driver, I commute an hour each way across LA. 80mph, stop and go. 4spd and manual brakes, wouldn't have it any other way.
Should be finishing my 461 in the next month or so!
Old 12-27-2019, 08:32 PM
phil400's Avatar
phil400 phil400 is offline
Usually around 2k a year, +/- some years. The winters seem to getting longer here�� so that shortens up the season, may till early November, I don't drive once they've salted
Last summer we bought a pop-up trailer, the kids love to go camping, we all do, so those longs wknds we're gone, the car sits..but I've had it 20 years...its there when I need/want it, like an old friend, over that time I have used as a daily in summer, I've road tripped it, beat the crap out of it, cruised, to just sitting for month, I don't think it really matters as long as you enjoy it. I don't care what it costs, I'll be dead before it's someone else's.
78 T/A 4SPEED, Original paint, match #’s, stock original bottom end, milled 6x-4s, HE268H cam,17058263 Q-jet/ 72 jets, CH secondary rods, RA Manifolds, poly body bushings, Moroso SFCs, 3rd and last owner since ‘99, as long as I'm alive.
79 Parisienne originally 305 2bbl now 87 350 tbi swap, 193 heads, performer, Q-jet, headers
77 t/a sold
85 Monte Carlo SS sold
83 Mustang GT sold
Old 12-27-2019, 09:03 PM
mechanickeith's Avatar
I put 46,000 miles on my 65 Grand Prix in 22 months. Does that count??
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
  #38
Old 12-27-2019, 09:09 PM
That's what I like to see! Drive and enjoy!
Karl
  #39
Old 12-27-2019, 09:18 PM
MUSLCAH MUSLCAH is offline
Well...up here in the Northeast....it naps for 6 months.....I try to drive it to work ...20 miles one way ...at least 2-3 times a week on the nice days. Then all weekend...coffee runs...grocery stores...cruise nights...
  #40
Old 12-27-2019, 09:22 PM
tom s tom s is offline
I used to drive a lot more miles but our freeway traffic has become so bad no matter what day or what time I just dont do as much.I will drive the 62 GP 421 virtually every Sat AM to Donut Derlics as it has a heater.The first and last Sunday of the month I drive either the 455 (soon to be 428 RA V)69 bird or the 421 SD 63 Lemans depending which on is on the top of the lift to another show and shine.I used to drive as far as San Diego on a weekend about 160 miles round trip but not any more.Tom
