Old 01-29-2020, 12:06 AM
pontorquer's Avatar
pontorquer pontorquer is offline
Rocky, would this mean these SR 455 4 bolt main are 455 HO service replacement blocks ?
Old 01-29-2020, 12:22 PM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
Technically, yes, but because the '71-72 455 H.O. shared the same short block with the standard 71-74 455, there really isn't anything unique about the 71-72 455 H.O. beyond its four-bolt main caps. Basically, if you were warrantied (or purchased) an SR 455 during the early '70s, the SR fitted assembly you received was equipped with four-bolt main caps regardless of whether the original application was a 455 H.O. or low-rpm 455 two-barrel. And that would apply to other sized SR blocks produced during certain years like the 389, 421, and 428.
Old 01-31-2020, 07:53 PM
NotaT/A NotaT/A is offline
Not sure if these pictures help you or not Rocky, but here is what I have on a 69 RAIV SR block.
Name:	69 RAIV SR Engine part number.jpg
ID:	530674   Click image for larger version
Name:	69 RAIV SR Engine serial number.jpg
68 F/B RA1 Coupe
69 F/B Convert
2000 F/B WS6 Coupe
Old 01-31-2020, 10:53 PM
Thanks! Do you happen to know the date code on the block?
Old 02-01-2020, 04:45 PM
Sorry that I left out the date code.
It is B212.
68 F/B RA1 Coupe
69 F/B Convert
2000 F/B WS6 Coupe
Old 02-01-2020, 05:10 PM
Thanks!
Old 12-29-2021, 08:47 PM
bankbook's Avatar
bankbook bankbook is offline
Rocky,
Here is my entry.
73 455 SR Short block.
The numbers on the front of the block are :
SR 82448
And by the distributor:
K263
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
Old 01-02-2022, 10:53 AM
moparcolt's Avatar
moparcolt moparcolt is offline
Rocky
I dont have a picture on my computer, but here are the numbers of my 70 ram air 4 replacement block.
stamp on the back of the block is 9799915 original casting number is ground off and this number is stamped over it.
the SR # is SR87328
it was cast E262, May 26 1972
it had a 9794054 crank, super duty rods and 722 X heads on it
Chris Collier
1969 firebird, pro touring build. Full Global West suspension 474 Stroker with Molnar Crank and Rods, DCI Ram Air 5 Top end, Holley fuel injection, Vince Janis 200-4R trans
"There is no such thing as too much horsepower"
Old 01-02-2022, 10:59 AM
AG's Avatar
AG AG is offline
I have a 455 SR engine that is dated from 1973 that was bought in the 1980s sometime.
Old 01-03-2022, 12:47 PM
Thanks for the info, guys.
If there's anyway you can send photos of the SR number, the casting date, and the casting number/stamping, I'd appreciate it. Also, if the pan is off, I'd like to see the main cap numbers.
Old 01-03-2022, 12:52 PM
moparcolt's Avatar
Here's the stamp and SR#
Sent from my SM-G973U using Tapatalk
Chris Collier
Old 01-03-2022, 01:12 PM
Thank you, moparcolt!
Old 01-25-2022, 07:26 PM
moparcolt's Avatar
Rocky, I sent you a PM about another one
Chris Collier
Old 01-26-2022, 05:36 PM
Thank you!
Old 01-27-2022, 01:56 AM
John Eiseman's Avatar
John Eiseman John Eiseman is offline
Default 70 SR 400
This one 70 SR 400 block is SR81318 and is a #9799914 cast with an early build. Maybe an H or I of 69 date.code? Will check exact date later for you.
Old 01-27-2022, 10:37 AM
Thank you, John. Any pictures you can post or send of the casting number (or stamp), SR number, and cast date would be a help so I can photo-document it in my files.
Old 12-12-2022, 12:16 PM
G.T.O.boy G.T.O.boy is offline
Rocky,
Here are some numbers as I have been trying to do some research for a replacement of my 64 389 76x block which is not repairable
these are from Ebay (still there)
9792506 built A229 SR82002 4bolt block number ground then stamped
9799914 built F071 SR812192 4bolt block number ground then stamped
50081 built B256 SR89716 455 2bolt cast part number
will need to get the numbers off my 64 389 SR Block that I found when I get back from machine shop
  #38
Old 12-12-2022, 12:36 PM
25stevem's Avatar
25stevem 25stevem is offline
As far as I know there where no 4 bolt 389 blocks in 64 and up thru the last in 66.
I do stuff for reasons.
  #39
Old 12-12-2022, 12:51 PM
Yes you are correct, just sharing info with Rocky for his research, these are 400 sr blocks and 1 455
  #40
Old 01-18-2023, 04:20 PM
Gordon Church Gordon Church is offline
SR 87852 400ci 9790071 hand stamped….casting date ‘71
