Old 02-02-2020, 03:45 PM
OG68 OG68 is offline
I've used the Parts Place paint. Somewhat darker but tolerable. I've received PP items from Ames before. Be interesting to see if they use their paint too.
Original on top.
Old 02-03-2020, 09:57 PM
alsalp alsalp is offline
I just installed the aluminum backing under the new applique I installed on my dash. It fit reasonably well, just some minor filing and trimming here and there. My point is mostly about the material of the applique. The reproductions have always been like contact paper, where as the originals were thicker plastic and had a laminated quality in addition to the metal backing - at least to my recollection.
I believe the original decal inserts were applied over the pebble background. It makes sense to me that they'd use the same dash for Tempest, LeMans and GTO and just put woodgrain on the higher trim models.
Who did you buy your new dash bezel and wood grain and aluminum backing from? was the aqua green color correct?
Old 02-03-2020, 11:24 PM
Verdoro 68's Avatar
I have an original bezel I had rechromed about 20 years ago. Still holding up great. I got the aluminum insert and wood grain from Ames a few months ago.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 02-03-2020, 11:29 PM
anyone install a repo bezel? Happy with the fit and quality?
Old 02-04-2020, 09:09 AM
Va68goat's Avatar
Va68goat Va68goat is offline
The top one is original that came with my car. The bottom one I got from Ames. I know it was cut at the radio but if someone is interested in my original one, I'm willing to part with it. It's just sitting in my garage and I have no use for it.
Old 02-04-2020, 10:44 AM
I see that they recommend one vinyl insert over another in the Ames catalog. Which one did you use?
It appears to have a slightly bigger gap around the instrument openings than the ones I've used in the past? Or is that an illusion?
Old 02-04-2020, 11:20 AM
How did you like the fit and finish when you put it in?
