Old 05-18-2020, 08:09 PM
Gator67's Avatar
Gator67 Gator67 is offline
I am interested in this for my pro-touring Formula project, but would like to see the list of other things I would need to buy.
Old 05-18-2020, 11:00 PM
takid455 takid455 is offline
Send a message via AIM to takid455
Originally Posted by Don Keefe View Post
If you are ready to market this, please let me know. donaldjkeefe@aol.com or 585-489-9826.
Will give you call Don .
What ignition s are you using for your system.
Not the normal "COP" (coil on plug) or "CNP" (coil near plug) configurations normally used.
Coils and bracket to mount them really nice work but they take up a lot of space it appears.
Tom V.
The GM coils don't seem big, but packageing 8 of them takes a little bit of real estate. For this application, I choose the GM 0411 ecu for all drivetrain related controls. Didn't want multiple control boxes. Just 1 doing it all. That's one of the reasons I made this. You can use other ECUs such as Haltech, Motech, MS3Pro, ect. Have the 58x setup designed which I'll start with the GM E38 ECU.
Originally Posted by Scott65 View Post
Nice job, and nice car.
Thanks! Its been a fun adventure.
Originally Posted by krisr View Post
That's awesome man! 0411 PCM's you can't really go wrong with considering how cheap they are and readily available.
Thanks. Its a great ECU thats been proven in a few million applications over a few billion miles.
This setup allows for personal preferences. The reluctors & sensors will work with other components. You have the freedom to choose what you want. You can go as much or as little as you wish.
A few parts
In-tank fuel pump. External will work but keep up with today's tech.
Fuel pressure regulator. Can use the GM filter / regulator is desired. That is not adjustable.
Any intake w/ injector bungs
Injectors
Fuel rails
Throttle body
MAP, ECT, IAT , & O2 senors
ODB2 port inside car
Harness, relays, fuses, ect
This application started with a stripped down 4th gen harness and integrated that into the car. Its separate from the body haness aside for some powers & grounds. This makes its easy to trace wires. Body is 78 Fbody, Drivetrian is 2000 F body. One could use a truck harness also. Wire colors are the same for arguments sake.
Optional:
Wideband O2 sensors, AC trinary switch, fuel pressure sensor
Depending on which ECU, you could even run a flex fuel sensor for E85.
Extra optionals the GM ECU allows
4Lxx trans
electric fans
electric speedo
AC
Ect
1972 HO Trans Am auto White/white
1974 SD Trans Am 4 spd, no a/c dk blue/ white & blue
1978 Trans am gold/ black ,T56, t tops, EFI 474,
Build: http://www.pro-touring.com/showthrea...1978+g+machine
1999 30th Trans Am 6 spd, T top
Old 05-19-2020, 02:51 PM
Gator67's Avatar
A few parts
Injectors
Fuel rails
Throttle body
Optional:
4Lxx trans
electric fans
electric speedo
AC
Ect
I have a 5th gen ZL1 fuel pump module (in tank w/built in regulator) and Vaporworx PWM controller so I can run returnless, but starting from scratch everywhere else. Car is not wired yet, so have lots of degrees of freedom there. This seems like a better option than the EZ-EFI 2.0 TB system I have on hand and was planning to use, but I have a lot of learning to do. Where to begin?
Old 05-19-2020, 03:57 PM
Scott65's Avatar
Scott65 Scott65 is offline
Not to be a smart a#%, but begin at the beginning. The manuals for hardware installation, and tuning software. Also, make sure you have an understanding of generally what the sensors are, what they do, how they're used in combination to make it all work. Basically an efi basics type thing. I spent a couple of years studying all of it, just to make a decision which ecu I wanted to use. Also, study up on noise, and grounding. Wiring mistakes will sink even the best system.
Old 05-19-2020, 07:13 PM
krisr's Avatar
krisr krisr is offline
I'm going to shamelessly plug the folks at DIY Autotune, not because i'm a solid fan of the Megasquirt range, but because of this book --> https://www.diyautotune.com/product/...tems-hp-books/
Recommend anyone who's not played with EFI before, read that. I'd rate it as an entry level type of book into the world of EFI.
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120
'66 Pontiac GTO - 389, 4 speed street cruiser
Old 05-19-2020, 07:50 PM
Scott65's Avatar
That was part of my studies as well Kris.
Old 05-20-2020, 09:49 AM
Gator67's Avatar
That was helpful information. Just ordered one.
Old 05-20-2020, 10:15 PM
When learning EFI back in the TBI days, I related the different components to those of a carb which I knew very well. While they don;t 100% crossover, it'll get you going and you can build your knowledge from there.
Old 05-21-2020, 09:00 AM
1966socalgoat 1966socalgoat is offline
Holley efi and their distributor will work as well.
Old 07-04-2020, 01:46 PM
Revised the crank trigger. Will have about a dozen sets ready to go very shortly.
Name:	Pontiac 24x small.JPG
Old 07-05-2020, 12:46 PM
AIR RAM AIR RAM is offline
Will your reluctor wheel bolt to an ATI superdamper?
I am seriously considering using your system... And the distributor / oil drive plug, is that your design or is it an aftermarket one? This is the only complete system I have seen for a Pontiac...
SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t"
Old 07-05-2020, 01:20 PM
ATI list their diameters at 7.074" OD & 6.325" OD. The small dia offering most likely won't work as the mounting holes would be too close to the OD. The larger would mount OK by the trigger wheel teeth would not extend beyond the OD much. Not sure how it would affect the sensor's pick signal. If the balancer is solid for the first 1" +/- from the OD, drilling & tapping it should be an issue. The sensor hold allows forward and rearward adjustment to compensate for different banacer thicknesses, thus that aspect isn't and issue. Would need to see and or speak with ATI regarding their balancer design.
The distributor / oil drive plug is my design.
The Following User Says Thank You to takid455 For This Useful Post:
Old 06-08-2021, 02:36 AM
BossBird BossBird is offline
Any updates on this system?
Old 06-08-2021, 07:59 AM
I have all the components to ship. I've had in operation for about 2 years. PM with any questions & inquiries.
Old 06-22-2021, 10:47 AM
67Fbird's Avatar
67Fbird 67Fbird is offline
I am interested in "updating" my injected bird. Currently running commander 950 (circa 2008 ...batch fire system) and due to ANCIENT technology I am curretnly UNABLE to do anything with said system due to not having a windows XP ....(long story on the software stuff). So what/if can we do to get to the finish line.
Old 06-22-2021, 01:24 PM
That's funny, I was running the Projection 4i before designing this. I ran into the same issue you did in terms of limitations. This is bring you up to current times. Contact me via PM or email and I will be glad to discuss.
Old 06-23-2021, 10:04 AM
rohrt rohrt is offline
Wow nice!
What wheels are you running?
Tell me about the front suspension.
Tell me about the air condition. Looks like a mix of old and new?
What serpentine system is that?
  #38
Old 06-23-2021, 10:28 AM
Wow nice!
Forgeline WC3
Mix of Global west, Pro touring Fbody (upper arms, true coil overs with adjustable ride height via jack screw) & HO racing (sway bar). Seam welded subframe
Yes. Sanden compressor on an otherwise factory setup
Billet Specialties
  #39
Old 08-18-2021, 11:59 PM
I will be at the TA Nats with this system in operation. Look for a Gold 78 TA in one of the modified classes. Possibly super Street by their classification.
  #40
Old 01-10-2022, 04:56 PM
Murf Murf is offline
What is the current status of this setup.
Murf
