Use a bore scope and look inside of it stop the guessing someone near you has to have one you can use. We picked a washer out of a cylinder one time.
Not to sound like a jerk, but this happened a year ago and your just decided to get on it. Hmmm, That would be alot of sleepless nights for me. Just saying. Anyhow, I'll Apologize now in case I've offended you. I would do like everyone has suggested. Remove Distributor, plugs, flexplate, all belts and anything else connected to the engine. You can check the status of the valves. Should all be closed. I guess you could remove the rockers and pull out the pushrods too. Hopefully nothing fell down the intake. Remove the intake also, so you can see down the ports. And last you can pull the oil pan see what is going on. Anyhow, good luck. Please let us know what you find. Charles |
I'll air up the cylinders today to make sure all the valves are actually closed and tomorrow I'll get a new borescope.
No evidence of mice anywhere. Puzzling for sure, appreciate all the responses. I guess if I find nothing in the holes I'll start tearing down.
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot 1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @164 3500+lbs 10.5W's SOLD! 1964 421 GP-Sold 6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold |
With the valve covers off you can remove all the rockers and pushrods. All the valves will then be closed. If one is stuck you will notice it. Charles |
Well...mystery solved.
The nut looks to be from the ones I used on the carb. It must have fallen in on removal and over the time of periodically rolling the engine over must have fallen into the hole. Which now explains why one day it just stopped solid. First time this has ever happened to me! Lol
Congrats on finding the issue. I'm sure that's a load off your mind
Kevin |
No joke! What a relief and fortunately no damage
Great story with a happy ending! We had a nut smaller than that fall of a temperature sensor in the air hat on the dyno at speed. The amount of damage was epic! Cracked cylinder walls, (2), bent valves, all kinds off carnage. Not a Pontiac, but ugly anyway.
Nuts can get a person in trouble, Super Tuesday is this week.
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
