Old 03-30-2020, 07:05 PM
ladytata's Avatar
ladytata ladytata is offline
Originally Posted by eaglesan13 View Post
Cool car, congrats!
Thanks, getting it somewhat together to drive this year
Old 03-30-2020, 09:29 PM
dpoltzer's Avatar
dpoltzer dpoltzer is offline
Looking good there Lady! Happy for you.
1970 T/A
The Following User Says Thank You to dpoltzer For This Useful Post:
Old 04-13-2020, 01:39 PM
Originally Posted by ladytata View Post
no defog, no hood bird auto car
It must have about most every other option available besides those 2 then.
Almost $6400 is a steep MSRP even on a SuperDuty with AC
Spill the Beans on that Invoice !
Monk King is a cool place to come from.
They sold lots of HiPo Poncho and had a race team.
PY member supcarbob was involved there, and they still have a lot of dealer paperwork on the cars, etc..
Congrats
PS- fwiw- you have to let these engines warm up good before you go revving on them - or you can blow the oil filter loose.
Messy and Scary
And don't run any oil above 10/w30 unless it really really needs it.
Creates even more chance on the oil filter deal.
Make sure oil filter is a little 'extra tight' every time with 10/w30 and all is well after warmed up.
They also run even better with recalibrated carb rebuild parts/advice from Cliff R.
Old 04-13-2020, 09:04 PM
ladytata's Avatar
Thanks Mr Zep, yes and no,it does have a lot of options, expect trunk pop, defog, 8track and no bird, the honeys where added, really came with rallies. At least I’m able to drive it now, I’m stuck on waiting for my radio to come back from being converted and trying to dry fit a/c unit on over the heads that have girdles, if I can’t get it on I’ll have to take them out. I’ll post phs later
Old 04-13-2020, 09:10 PM
ladytata's Avatar
And what color is the trans tube????
Old 04-13-2020, 09:38 PM
ladytata's Avatar
Here you go
The Following User Says Thank You to ladytata For This Useful Post:
Old 04-13-2020, 10:06 PM
Best can recall the trans dipstick tube is natural.
Like aluminized steel or galvanized steel.
Thanks for sharing the Invoice.
Its loaded up pretty well with nice stuff.
Was just a caution on the oil stuff - they don't pop off oil filters all the time.
But it's an 80 psi oil pump in these, and they pump really hard when oil is cold.
I blew the oil filter loose on my 73SD after the first oil change i did on it.
Didn't let it warm up enough before revving it some to test some other adjustments.
Was sitting still - in the carport - when it happened.
Scary and Messy , learned my lesson , never happened again.
And i drove it hard plenty of times, at full operating temp.
No worries
Another guy i know did it too, but he had used 10/w40 thinking it was a good idea for summer running.
Old 06-16-2020, 12:51 PM
sdbob sdbob is offline
I've used 10-40 since mine was new. Driving only in warmer weather, May- October. Seen 6200 couple of times. Though I usually shift around 5400. Used,GM filters, Lee maxi,then Fram HPs. Now NAPA gold.Never regular Frams.
Old 07-15-2020, 05:56 PM
ladytata's Avatar
Did the sd come with this vacuum delay valve?
Old 07-16-2020, 02:50 PM
formula kid formula kid is offline
Yes
The Following User Says Thank You to formula kid For This Useful Post:
Old 07-16-2020, 03:38 PM
ladytata's Avatar
I have no clue what one looks like? Anybody have a pic, this is what I found in my shop
Old 07-16-2020, 04:26 PM
looks like the two sections of hose with the delay valve in the middle would be correct set up
Old 10-04-2020, 09:29 PM
ladytata's Avatar
What does the clip look like that attaches the oil dipstick tube
to the upper a/c bracket?
Old 10-05-2020, 08:16 AM
From 73 Assembly Manual:
Basically the bracket is horizontal on SD and vertical on regular Pontiac.
(plus on different AC bracket.)
Old 10-05-2020, 08:23 AM
ladytata's Avatar
Yes but I believe there’s a clip that goes on here so you can screw the oil tube to the ac bracket
Old 10-05-2020, 08:30 AM
The AC bracket is threaded so no clip. (like the standard one does)
Old 10-05-2020, 09:53 AM
ladytata's Avatar
Stand one has a clip, but you might be right on Sd. Thanks
  #38
Old 10-05-2020, 02:34 PM
Yes, I worded that weird.
SD AC bracket was threaded.
The standard setup had no hole in that bracket and the rear bracket had a clip for the tubing.
  #39
Old 09-11-2025, 03:56 PM
agugliel74SD agugliel74SD is offline
I purchased the SD car a couple of years ago in Indianapolis Indiana from the original owner and completely restored the car. It came complete with all the documentation, an extra set of honeycomb rims and an original tube of decals which were in the basement and unusable.
The Following User Says Thank You to agugliel74SD For This Useful Post:
  #40
Old 09-11-2025, 04:00 PM
I purchased the SD car a couple of years ago in Indianapolis Indiana from the original owner and completely restored the car. It came complete with all the documentation, an extra set of honeycomb rims and an original tube of decals which were in the basement and unusable. Click image for larger version
