I’m dialing it in for you LOL
It will be flawless provided you put the correct parts in it. Those carbs are basically a factory "high performance" part, de-tuned solely to get them thru emissions. They are missing the outer booster rings, so not tuned like the standard units. Other than lean right off idle and at light engine load they aren't lacking anyplace else.......
Sure. We're on lock-down here and have been for weeks. With most of working America at home right now call volume is heavy. Haven't been able to get much done in the shop, but I like the parts business better anyhow........
Sent request via your website. Cheers, Bruno |
