A fwiw, Canton recommended pickup to pan clearances of 5/16-3/8 inch. And mention the gaskets will add some additional clearance.
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
Tom V.
Perhaps I am missing the obvious, but something that is fuzzy to me...
...what negative effects are there if the pickup is higher off the pan floor than ideal? I understand that the pickup cannot be too close to the pan, or else it hinders suction and could affect flow. But what bad happens if the pickup is say, 1" off the floor? The only thing obvious to me is that you loose some oil capacity in the system, as the oil that cannot get sucked into the pump effectively disappears as it cannot be used...but is that it? Thanks
Michael 1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished! 1979 Trans Am - low-buck drag car project for when I retire |
If you are a drag racer or road racer and the pick-up is 1/2" higher vs the upper height distance, then when you accelerate (or turn corners sharply), the pick-up being slightly higher has more chance of seeing air vs oil and you would then be adding air and oil mix to your engine. Road Race pans have trap doors to keep the oil from running away from the pump pick-up. This means the average oil level in the pan around the pick-up is higher and less chance of air entering the engine. Some put a deflector baffle on the back wall of the oil pan (about 3 inches up) to force the oil climbing the rear wall under acceleration to turn quickly back into the sump and keep the pick-up covered. So if you drive smoothly it makes no difference, if you drive like a NASCAR guy or a Drag Strip guy you need mods besides the stock oil pan. making sure the pick-up is about 3/8" is in the ball park for a good location but does not fix a racing oil starvation issue. Same deal for slamming on the brakes and having the oil run to the front of the pan on hard decels after the pass. Tom V.
| The Following 2 Users Say Thank You to Tom Vaught For This Useful Post: | ||
Another way to look at it is that 3/4" of oil (increase from 1/4" clearance to 1") the engine no longer has access to is about 8/10 of a quart. So in reality it should be the same as running the engine about a quart low on oil.
I'll add one more to Tom's list of when it might matter -- Early Edelbrock heads were notorious for holding oil up in the valve cover area, and the missing oil might be the difference between an engine that lives and one that fries the bearings - and no drag racing needed, just buzzing along at a good clip down the freeway.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 Catalina Safari Wagon. |
Tom V.
No long weld bead. Just small tack welds in several places.
And the pick-up is supported by the tube inserted in the casting. It has worked well in that location for years and millions of miles on a fleet of Pontiac vehicles over the years. The 22 gage strap is fine. If you use a vice grip you can get the reinforcement piece around the tube a bit tighter but the pickup should not loosen with just a few tack welds on the support piece and the tube. Find where the tube rests closest to the strap and tack weld it at those locations for less stress on the welds. Tom V.
I usually grind the pump cover plate so I can adjust the pickup to where I think it belongs, about 3/8” to 1/2” from the bottom of the pan at the lowest point of the pickup. It ends up sitting at an angle of course but not too severe.
Putting the pickup in the notch seems too high in my opinion. I use either a ball of foil or modeling clay to determine the clearance. Never had any issues doing it that way. My experience is with 13-second daily driver street engines and low 12-second bracket race engines usually not spinning much more than 5500 rpm using the 60 psi Melling pumps. Never welded the pickup in place or used any support strap. I drilled and tapped the pickup tube and pump body where they mate to secure the pickup, 10-32 socket head cap screw installed using red Loctite. My latest engine (mostly stock/restored 421 HO) was built by a friend who prefers to tack weld the pickup, he has built numerous engines for himself and other friends with no issues so I had no problem with his method of securing the pickup.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
i trim pump cover so i can get pickup height we’re i want it putting screen in notch makes screen a little to high
2008KRE Q16 Winner 2014 atco raceway doorslammer winner 86 grand am tube car 8.95 @152 455 eheads solid flat tappet cam Hoffman Racing building and racing Pontiacs for 35 years |
b-man, I fabricated a bracket to hold it in place. Scroll down a bit and you'll see pics. I'll be drilling holes in it yet to weld to. Thanks again guys! |
Looking at SusieQ's, oil pump picture, I have a question:
a) We already agree that the pump screen should not fit into the notch but the screen "lip" should be a bit lower on the pump and flatter on the bottom of the oil pan. b) Most agree that a strap is not a bad idea to retain the pick-up to the pump. So here is my question/ proposal. If you mounted a flat strap on the bottom of the pump, (but not to the bolts closest to the pump inlet but the ones closest to the "notch" on the pump, and then located the screen so that it was more "flat" when installed in the pan (by welding the strap above the lip on the top of the pick up screen) then three things would happen. a) The screen would be flat with the oil pan bottom surface. b) The bolts/strap would securely keep the screen from vibrating (because you are not using the notch (which was cast in the pump housing for that purpose in the oil pump design). c) The screen once installed could not come out of the pump because it could not move due to the oil pump cover "retention" fasteners and fabricated strap. Tom V. You could call it the Susie Q "Oil Screen Mod".
| The Following User Says Thank You to Tom Vaught For This Useful Post: | ||
I'll grind down the lip that prevents the screen from rotating downward to my desired position. Then I'll be drilling two holes in the strap at the tube and welding in those locations, as well as drilling a hole in the part of the strap that wraps around the tube, tightening it with Vice-Grips, and welding that. I can't see how it could ever move. |
Not saying in your case that you cannot do it exactly the way you described and with the bracket you currently have. Go for it.
That being said, at Ford we had welders who could weld a bead on .015" feeler gage strip steel with a TIG and not blow thru the strip. So the oil pump screen housing thickness would not be an issue for some. Do not change what you are planning on doing. I was suggesting the relocation of the strap for others who might want to do something similar to what you did. Tom V.
After reading all the above, and since I have the original 1968 242 block, pan and pump, I decided to investigate how it came from the factory. With original pump bolted in and block upside down, I measured the tallest point of the tilted screen 7 1/8" from oil pan mounting surface on the block. When I went to measure the pan depth, I wondered where to take my measurement, so I put a roll of tape on the pump intake screen and placed the pan (with drain plug in it). I discovered that the pan cannot be placed directly inline with mounting bolt holes, it needs to be be moved forward and then rear again for the screen to clear the drain plug. No one would normally notice this because the drain plug is removed before the oil pan. Due to the curved inlet pipe, the screen can pivot to avoid the drain plug once installed, but cannot be forward enough to miss it entirely. This tells me that, from the factory, the intake screen is installed so the drain plug end comes in above it, and that the screen itself tilts down into the well leading to the drain plug.
My new Melling M-54D-S came with intake screen tube 1/2" shorter which moves it off center toward passenger side but same front to back. It can ever interfere with the drain plug, but will miss the drain plug well so will need to be shallower than the original just to not hit the bottom of the pan. |
