Nope. There was a Beaumont (essentially a Chevelle with Pontiac styling cues) and the GTO.
So this car:
https://www.ebay.com/itm/353077192807 is a 1966 with a 400 and tri-power. From what you said, the 66 only came in a 389, and would the tri-power set up for a 400 be different than a 389 (different intake, etc.)?
1965 Buick Riviera GS 1965 GTO Tri-Power convertible 1965 Jaguar XKE Series 1 Coupe 1967 Corvette L68 convertible 1967 GTO 400 convertible 1968 Camaro 396 SS/RS convertible 1969 Plymouth GTX 440 1969 Mach 1 R-Code Cobra Jet 1970 Olds 442 W-30 1970 Buick GS 455 Stage 1 1970 Dodge Super Bee Hemi 1977 Pontiac Trans Am W72 SE 1978 VW Beetle convertible 2011 Mercedes SLS 2013 Jeep Wrangler Rubicon |
400 never had a Tri-Power and first year for the 400 was 1967 in a GTO.
A 389 tripower (TP) can be used on any size engine (I think the 301 may be an exception) as long as it matches the heads; 64 and earlier TP must be used with 64 and earlier heads and the 65 & 66 TP is used with 65 and later heads. TP was also used on the 421. The TP option ended at the end of the 66 model year so there is no “400 TP”, just bolt-on retro fits. I suggest you do a search for Pontiac TPs to answer your questions. There are numerous sites that detail various years TPs and their applications and differences. |
As mentioned 1967 was the first year of the 400 - which was essentially an update on the 389 (bore increased);
Also at that time GM issued a decree that banned multiple carburetion for the 1967 model year on anything except a Corvette. I seemed to recall something changed with the intakes right around this time, and a quick google search showed that the intake manifold bolting pattern changed for 1965, so any 1965-1966 Tri-power intake manifold should be able to be made to work with any 1965 & later heads. The bigger change in top ends was the combustion chamber design which changed in 1967 - the early 1967 & older used a closed chamber design, while late 1967 and newer went with an open chamber design. At least the seller was honest about the engine size - because externally they are virtually identical - unless you know what to look for. I would suspect that most people restoring a pre-1967 GTO would opt for tri power, because it was proven to make more power than the AFB that would otherwise be there... and come on, they look cool
A quick education when looking at Pontiac Engine blocks.
389 = two freeze plugs on each side of block. 400 = three freeze plugs on each side. Chris. |
Does anyone know on what date that the last tripower GTO rolled off the line? I've read that tripower was discontinued halfway thru the '66 model year, but never saw a specific date.
When I'm paid, I always follow my job through...you know that. http://www.youtube.com/watch?v=Al2b-...eature=related |
/\ I'm not sure where that would have come from;
the GM mandate against multiple carburetion didn't take effect till the 1967 model year; And assuming that the 1967 model year was like others after it, would mean it actually started around Aug/Sept 1966; So if the model year is Sept through to July, that means the halfway point for the 1966 model year would have been somewhere areound February 1966.
I have several folders of Original Survivors factory equipped with the 3x2s well into July of 1966.
Beautiful sprint Jeff! , I found what I believe is a factory air cleaner to a 66 sprint, it has a longer throat to the carb then an AFB has, Jeff what is it worth ? It’s not mint, but not Junk either, thanks mike
