Old 06-03-2020, 01:59 PM
starlightblack's Avatar
starlightblack starlightblack is offline
only SHOULDER belt delete
"Spend all your time and money on that Pontiac GTO pile" - The Go-Gos, 1981
The Following User Says Thank You to starlightblack For This Useful Post:
Old 06-03-2020, 03:33 PM
I exchanged emails with the owner. It had partial quarters and the trunk floor replaced several years back. Per the owner's statements, it was exported to England, restored there in the mid-90s, and then went to Canada in the mid-2000s. It also has some modifcations such as sub-frame connectors. There are a lot of things that are incorrect but it is a true SD car.
I have a numbers matching red 73 T/A 455 4-spd that was hit in the front end. Body shell is excellent, but the sub-frame was damaged. I also have a complete SD motor with no codes or SR numbers at all that I was planning to use in this car. My goal was to build a 73 SD455 4-spd with a/c built as a touring car when I retire. It will definitely have some modifications beyond stock so numbers match is not a problem. I was considering selling my wrecked 73 as a numbers matching standard 455 4-spd car, then sell the SD motor separately. The proceeds would put a big dent into the cost of this car, which I could drive right away. After digging into the specifics of the car, I'm not thrilled that that it has rust repair.
Old 02-15-2022, 05:06 PM
Back again
https://www.ebay.com/itm/31384460252...=10001&mkevt=1
It was 53K on Craigslist in 2020
Old 02-16-2022, 10:47 PM
muscle_collector's Avatar
so whats the deal on this? i saw it on barn finds and it said it was originally a Y code regular 455, which would be correct for one with 4 speed and ac.
Old 02-16-2022, 11:03 PM
This SD TA is N139197 correct?
It was originally an automatic SD car with AC. Someone in early life, put a 4 speed in it. It also did not have it's original SD engine at some point when overseas. (had a 400 in it I believe)
It went to Canada sometime after a 'restoration'.
It acquired a SD engine along the way also.
Red with 461 custom interior. Seat belt deletes.
Old 02-17-2022, 09:28 AM
it is properly listed as an X code SD on that site
Old 06-03-2020, 05:25 PM
Transamric's Avatar
And what's with the '71 - 72 seats and outer seat belt? Odd!
Old 06-03-2020, 08:13 PM
daduck's Avatar
daduck daduck is offline
I would describe that as Ruff.
And if it has been in Houston any length of time, the salt air is doing it's corrosion thing 24/7.
Old 06-04-2020, 10:59 AM
JonQ JonQ is offline
Do you mean Galveston? I've never seen it in Houston unless you live way near the coastline.
Old 06-04-2020, 09:56 PM
JAL71TA JAL71TA is offline
no salt air in Houston....humidity but all the salt air is in Galveston and Corpus
Old 06-03-2020, 09:23 PM
1965gp 1965gp is offline
I don’t seem to have much trouble with salt air in Houston- I’m about 80 miles from the coast. In Galveston it’s a completely different story.
But, most of my cars are stored indoors
Old 06-04-2020, 10:33 PM
JAL is in the same area I’m in (Spring) and most of the cars here are pretty clean if they are taken care of.
Old 06-05-2020, 07:10 PM
Formulabruce's Avatar
couple things, 1. you cannot delete shoulder belts. they became DOT Mandated in January of 1968, and GM did Not install them till they absolutely had to as prices were set. So, the deletion is to Delete "standard" belts with a credit because the deluxe interior already has deluxe belts.
2. car insurance. trying to get a regular insurance adjuster to pay 53K for this car totalled would be a miracle. only a real Agreed value policy will pay that kind of cake.
Old 06-06-2020, 01:01 AM
It was an export as new
You could delete the seat belts, and in some cases the heater/defroster, on those exports, depending on the requirements in that country.
And at the request of the consumer.
Very few examples of these deletes come to light for everyone to know about them as general knowledge.
This car was ordered with all seatbelts deleted per the invoice.
2 separate credits
for shoulder belts (A56)
and for lap belts (A48)
You won't see these two type credits on any US or Canada sold cars in 1973
All the 73 TA's and 73 SD Formula's received a discount of $27.00 Retail for Non-Functional Shakers.
Old 02-17-2022, 10:11 AM
Big Bear's Avatar
Big Bear Big Bear is offline
Pictures when for sale in 2017 in Canada. Asking price at the time was 100k cnd
ID:	584257   Click image for larger version
ID:	584258   Click image for larger version
