Stan
Years ago I bought a brand new standard 2 circuit 1050 dominator from summit and did basic tuning on it for best ETs. Couple of years later I bought a pro systems new from them set up for my combo. Ran exact same numbers at the track. Tried tuning it but it didnt make any difference. The only difference was the PS carb idled a little cleaner/smoother.
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.45 @ 88.1 mph on slippery street tires.Bad 2.19 60ft.Owned since 86' |
If I can make the 720 or so horsepower in a 6500RPM 461 I think it will be an accomplishment. Getting it done on pump gas, no high RPM and without having a bunch of head work with all the expensive offset rockers and lifters would be something. |
All I do know is, tell Patrick exactly what your engine's specs are, what tranny, what gear and full weight and he will build you the carb you NEED. Tell Patrick what you WANT and you'll get what you get. Most everybody I know or have talked to said that they bolted their Pro-System carb on and the only thing they needed to do was adjust the idle.
I bolted my Pro-System carb on, adjusted the idle, made several passes, pulled out the NGK's and not only did they look good..... They were perfect! Can't thank Patrick enough as it would have taken me 1/2 the season of jerking around to achieve the same results. |
Stan
An image capture of this mystery program would be very interesting.. |
Is "your" software out of date or something ? Only thing that matters is my buddy has it and was able to talk Vizard into letting him purchase it. Not anyone can buy it. I am not going to pry and ask for screen shots or anything like it. Just happy he is kind enough to let me use it. |
Stan
Just finding to find out what he used. As I would ask David Vizard about it. Stan
Ok. Just wondering. I didnt see what difference it made. Whats the point of calling Dave V? To prove his formulas wrong or to check to see if Dragn is actually using them?
Why would I think David's formula is wrong? How would David even know who Dragncar is? I wanted to talk to David to see if he ever had software that does what Dragncar says he is doing or maybe the software Dragncar is using was not done by David. If you call Comp Cams give them your specs and they recommend a cam and then you call Lunati give them your specs and they recommend a cam. The 2 cams are not the same. Who is wrong, who is right? Just like with the carb recommendations you would need to dyno or race them to know. Stan
Lol.
Don't know David V, know someone who knows him and thats it. Not giving it up either. |
Actually because of your posting history
I am just doing some fact checking. ![]() Stan
You are making a federal case about me having a friend punch in my numbers with a 1050 then a 1150. Big deal, get a life. I just thought it was interesting that one guy says 1050 will ET better but a 1150 will make more power. Just keyboard racing man. The real racing will start when I get off my lazy @ss and put this thing together. Working six 10 hour days right now so I have to force myself. |
#38
LMAO.. Stan is developing the newest for Vizard.
#39
#40
During the early 90’s David Vizard's Cam Master program was conceived and began to take shape. David and Denny Wyckoff at Motor Machine & Supply in Tucson developed the program, a comprehensive computer program that offered precise cam selection. It was a empirical program based on over 50,000 individual engine dyno pulls on various engine combinations. Written up in National Dragster and other magazines. Cam Master was not duration-driven but overlap-driven. The event timing of the cam, dictated by the duration of the intake and exhaust, together with the Lobe Center Angle (David used that term for lobe separation angle) and the advance/retard position in the engine. Once the overlap to suit a given application is decided, everything else falls into place. It was Denny Wyckoff that ran the program for the public thru his shop. Since then David has brought out different programs.
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
